Blu-ray Hostiles ripping in wrong order
socker_dad
Post by socker_dad »
I have attempted to rip Hostiles several times with a variety of settings and keep getting odd errors - not in the ripping process, but in the resulting MKV file: The order of the frames are occasionally mixed up.
For example: In the meeting with the Colonel and the Harper's Weekly douche bag (roughly 13:25 in) the scenes jump around in order. Later, about the 28-minute mark, just as Captain Blocker is about to enter the burnt-out house, the scene cuts back to the meeting scene, then after a few moments, back to where it was. I've tried this several times with different input files (there are roughly 390) and get the same results.
Any suggestions???
Re: Blu-ray Hostiles ripping in wrong order
Finding the correct title to rip would be the key. It sounds like you've picked a Lionsgate obfuscated disk, and haven't found the correct title to rip.
Did you not get a suggestion from MakeMKV?
Nucleus
Post by Nucleus »
socker_dad wrote:
Wed Feb 07, 2024 12:35 am
See links in my sig, identifying and ripping the correct title. This one and this one.
As @Woodstock has mentioned, typical of a Lionsgate playlist obfuscation. Scroll down first link to "An Update To This:".
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
A couple of other threads about Hostiles:
Hostiles - Playlist Obfuscation
Hostiles correct playlist
