using Docker autoRippingMachine on ubuntu server 22.04.3 LTS
alphaTangoSierra
#1 Post by alphaTangoSierra » Wed Feb 07, 2024 4:28 pm
when i insert a disc into my setup the drive it spins and reads the drive and looks like it is attempting to copy the contents and then it fails and ejects the drive
this Disc and Drive worked for MakeMKV on a Windows 10 machine
i have an external LG limp portable Blu-ray Multi Drive
model: CP40NG10 from june of 2014
im attempting to rip an iron man 2 Blu-ray i own and have successfully done so using make mkv on my windows 10 laptop
the process i used to create the linux machine i am using to automatically rip was setup using the following youtube video
https://www.youtube.com/watch?v=S2yze4DUCT0
and applied to it a old desktop i had lying around after putting ubuntu server on it specs:
OS: Ubuntu 22.04.3 LTS x86_64
Host: OptiPlex 790 01
Kernel: 5.15.0-92-generic
Packages: 754 (dpkg), 4 (snap)
Shell: bash 5.1.16
Terminal: /dev/pts/0
CPU: Intel i5-2400 (4) @ 3.400GHz
GPU: Intel 2nd Generation Core Processor Family
Memory: 533MiB / 7815MiB
here is my log file:
Debug log started at Wed Feb 7 13:43:33 2024 , written by MakeMKV v1.17.6 linux(x64-release)
001005:0000 MakeMKV v1.17.6 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///config/MakeMKV_log.txt
Using 6144KB for read cache.
Network access is ENABLED, CURL version 7.74.0/OpenSSL/1.1.1w/1.43.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at 1x16b4G!]9Eznq-@H9$38R:29393631
No SDF v098: HL-DT-ST_BDDVDRW_CP40NG10_1.00_20111010162300_KO1E5C94829
SDF id v098: HL-DT-ST_BDDVDRW_CP40NG10_1.00_20111010162300_KO1E5C94829
001003:0020 DEBUG: Code 1 at p9-a_I9y*I-TbuCo&P^OI:121265062
Application exited at Wed Feb 7 13:43:33 2024
