One DVD with 2 movies does not create 2nd MKV
MarkS85
Post by MarkS85 »
I bought a new movie that has 2 movies of a particular actor whose movies I enjoy. I am able to rip one of the movies, the 2nd on the DVD, from the DVD, however, I cannot extract a working MKV file for the 1st movie. I am able to watch both movies using TLC app on my computer, I just cannot extract the 1st of the 2 that shows up in TLC using MakeMKV, which I have been using for years for both DVDs and BluRay discs I own. When I run MakeMKV, the 1st movie fails to get created but the 2nd movie does. Not sure what is up with that. Is there a way to just extract the 1st movie as an MKV file? See attached screenshot of MakeMKV after running on DVD.
Re: One DVD with 2 movies does not create 2nd MKV
Your screen shot didn't make it.
Can you copy & paste your MakeMKV log into here?
Often, gently cleaning a disc and trying to rip again helps.
MarkS85
Post by MarkS85 »
See attached screen shots.
MarkS85
Post by MarkS85 »
and here is the MakeMKV log file.
Whatever you're trying to use to attach your log and screen shots is not working. The log can typically be included in the message between CODE tags.
DanHolli
Post by DanHolli »
The attachments didn't attach, but after the disc scan, does it only show one title? If so it was likely intended be the publisher. If it shows multiple titles it could be having issues reading the data of one of them.
If you have the first issue you can split the file by either chapter maker or time using a tool like MKVtoolNix to separate the movies
If you've got the second issue, it's either your drive is dying, the disc is damaged, or there was a mastering issue. MakeMKV cannot accommodate for the first two but might be able to be resolved by cleaning the disc and drive.
Moderately skilled script kitty :)
Automation is how I run
MarkS85
Post by MarkS85 »
I'm sorry, I was trying to attach files. Let's try this. Below is the log file text.
Debug log started at Sun Mar 03 22:00:18 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\mardia/MakeMKV_log.txt
No  SDF v097: MATSHITA_BD-MLT_UJ260AF_1.00_HP46__040588
No auto SDF v097: MATSHITA_BD-MLT_UJ260AF_1.00_HP46__040588
DEBUG: Code 0 at JH[R]Q46'ck{tMypQ:29396253
DEBUG: Code 0 at SM@e63jNU)cu"$Qt:213136746
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF id v097: MATSHITA_BD-MLT_UJ260AF_1.00_HP46__040588
DEBUG: Code 0 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 2 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 3 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 4 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 5 at MLcC`m@J,u_zIjQA5:121263199
DEBUG: Code 6 at MLcC`m@J,u_zIjQA5:121263199
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
DEBUG: Code 0 at _y<{y.H`KydrY`/TJ{+d:29396460
003025:0000 Title #1 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #2 was added (16 cell(s), 1:56:14)
003028:0000 Title #3 was added (14 cell(s), 1:56:17)
003028:0000 Title #4 was added (2 cell(s), 0:02:11)
003025:0000 Title #5 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at spVbPw4u54ZPfvgzv5BzSLy7:0
005014:0000 Saving 2 titles into directory file://D:/Video/7000096713.1
001003:0020 DEBUG: Code 0 at ^~E}#@`T8tSTx=mT~:213130237
DEBUG: Code 3056376704 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 2515836704 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 1975296704 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 3459456000 at V&j0H{;|9MhAp3\(,BP7:121270168
001003:0020 DEBUG: Code 4294967295 at ^,i~BX3is!O#bBE`7h\+r:29402164
001003:0020 DEBUG: Code 0 at ^t{bs*vL4zHMcbnfDdY:29396299
004004:0000 The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 2002944, attempting to work around
DEBUG: Code 2306304000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 180180000 at V&j0H{;|9MhAp3\(,BP7:121270168
004004:0000 The source file '/VIDEO_TS/VTS_02_1.VOB' is corrupt or invalid at offset 24563712, attempting to work around
AV sync issues in D:/Video/7000096713.1/B1_t00.mkv
AV sync in 1 at 1:06:03.401 (6.806s) : encountered overlapping frame, audio skew is +6.806s
DEBUG: Code 1434756704 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 894216704 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 353676704 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 4108104000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 3567564000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 3027024000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 2882880000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 2486484000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 1945944000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 1405404000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 864864000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 324324000 at V&j0H{;|9MhAp3\(,BP7:121270168
DEBUG: Code 1024 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=1024 acc_size=268566528 off=5856
 0: 00e0 off=270094
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 2048 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=2048 acc_size=268566528 off=5856
 0: 00e0 off=272142
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 3072 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=3072 acc_size=268566528 off=5856
 0: 00e0 off=274190
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 4096 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=4096 acc_size=268566528 off=5856
 0: 00e0 off=276238
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 5120 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=5120 acc_size=268566528 off=5856
 0: 00e0 off=278286
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 6144 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=6144 acc_size=268566528 off=5856
 0: 00e0 off=280334
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 7168 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=7168 acc_size=268566528 off=5856
 0: 00e0 off=282382
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 8192 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=8192 acc_size=268566528 off=5856
 0: 00e0 off=284430
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 9216 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=9216 acc_size=268566528 off=5856
 0: 00e0 off=286478
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 10240 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=10240 acc_size=268566528 off=5856
 0: 00e0 off=288526
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 11264 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=11264 acc_size=268566528 off=5856
 0: 00e0 off=290574
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 12288 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=12288 acc_size=268566528 off=5856
 0: 00e0 off=292622
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 13312 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=13312 acc_size=268566528 off=5856
 0: 00e0 off=294670
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 14336 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=14336 acc_size=268566528 off=5856
 0: 00e0 off=296718
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 15360 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=15360 acc_size=268566528 off=5856
 0: 00e0 off=298766
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 16384 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=16384 acc_size=268566528 off=5856
 0: 00e0 off=300814
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 17408 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=17408 acc_size=268566528 off=5856
 0: 00e0 off=302862
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 18432 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=18432 acc_size=268566528 off=5856
 0: 00e0 off=304910
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 19456 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=19456 acc_size=268566528 off=5856
 0: 00e0 off=306958
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 20480 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=20480 acc_size=268566528 off=5856
 0: 00e0 off=309006
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 21504 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=21504 acc_size=268566528 off=5856
 0: 00e0 off=311054
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 22528 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=22528 acc_size=268566528 off=5856
 0: 00e0 off=313102
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 23552 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=23552 acc_size=268566528 off=5856
 0: 00e0 off=315150
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 24576 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=24576 acc_size=268566528 off=5856
 0: 00e0 off=317198
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 25600 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=25600 acc_size=268566528 off=5856
 0: 00e0 off=319246
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 26624 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=26624 acc_size=268566528 off=5856
 0: 00e0 off=321294
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 27648 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=27648 acc_size=268566528 off=5856
 0: 00e0 off=323342
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 28672 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=28672 acc_size=268566528 off=5856
 0: 00e0 off=325390
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 29696 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=29696 acc_size=268566528 off=5856
 0: 00e0 off=327438
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 30720 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=30720 acc_size=268566528 off=5856
 0: 00e0 off=329486
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 31744 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=31744 acc_size=268566528 off=5856
 0: 00e0 off=331534
 1: 80bd off=5856
 2: 20bd off=24260
DEBUG: Code 32768 at W>+Ah>7{ZAf6']tj_cC:29396506
ak=1 seg=1 miss_count=32768 acc_size=268566528 off=5856
 0: 00e0 off=333582
 1: 80bd off=5856
 2: 20bd off=24260
001003:0020 DEBUG: Code 4294966995 at V&j0H{;|9MhAp3\(,BP7:213143669
001003:0020 DEBUG: Code 0 at V&j0H{;|9MhAp3\(,BP7:213140702
001003:0020 DEBUG: Code 0 at ^,i~BX3is!O#bBE`7h\+r:213137068
001003:0020 DEBUG: Code 0 at X1\<3JH#7DamPlL^:213132537
001003:0020 DEBUG: Code 0 at NLT&zN\H6oe5w(DTD:29396207
001003:0020 DEBUG: Code 0 at NLT&zN\H6oe5w(DTD:121264257
001003:0020 DEBUG: Code 0 at NLT&zN\H6oe5w(DTD:213130490
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
---- Failed D:/Video/7000096713.1/B1_t00.mkv
ch_0        4287130848000 0
ch_1        4287671388000 0
ch_2        4288464180000 0
ch_3        4289293008000 0
ch_4        4290121836000 0
ch_5        4290950664000 0
ch_6        4291455168000 0
ch_7        4292175888000 0
mt=00000243A2903650 n=3
s=0 n=1 o=342472704
    0  70316 000011  4292175888000       36036000 B4DADE8A 000001B32D01E034138823821020202620262C2C2C2C2C2C343034363636343434343636363A3A3A4444443A3A3A36363A3A404044444A4C4A464644464C4C50505060605C5C7070748A8AA6000001B51482000100000000000001B8086926C000000100000FFFF8000001B58FFFF79A00000001010B7E1F68D1A30C368D1A34
s=1 n=1 o=5996544
    1   1536 000001  4292179200000       34560000 B3B035D7 0B77FD2C1C30E1DFE5CBC924A00007FE9FDA96A284E2C0342C282C2A8C800C9161A132F16C04002E37AAB838EA1477CFA2AC3757250C7D5D2ABAD0A143855DF524A9A9AAAEEAB568539F2986F9F434AFA1490D074BC996103F01F51A70AC5774F51D7AEFDF57CD0DF38B0F9FCDB5B12BE542C87536EC3B8E522C7D09FAE80F6A
s=2 n=1 o=24842240
    2   2992 000011  4292824536000     3809280000 F6E90CA2 0BB00B9100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
mt=0000024391B6CC00 n=3
s=0 n=23 o=342472704
    0  12868 001010  4292283996000       36036000 F697AC12 0000010000D7FFFB80000001B5843FF79800000001011A6C04051B00000001021A6C04051B000000000001031A6C04051B000000000001041A6E113594F6ACB6EE7DD43658D15AC68AA0EA85D2F875F89D718CD23456C2E4BEB8733F334908AA61A30A027E2D903EE3F9868C17A0D182F5CE6592B8A0B8B2526A9A49491C4F92
    0   2516 001018  4292211924000       36036000 52F230BD 00000100005FFFFBB8000001B582242318000000010132AC04052B000000010232AC04052B0000000000010332AC04052B0000000000010432ACAB420206A6200000010532AE56D53548E566A61514E955AE7A8E9A70130F49699C4692E5D281A188A15914358A104B0B7D530F2B328560E50E9295BD644E6F60FC00354CE534
    0   9684 001018  4292247960000       36036000 21B54C1B 00000100009FFFFBB8000001B58433271A00000001011AAC04052B00000001021AAC04052B000000000001031AAC04052B000000000001041AADB98DC032AD057AE73017470ABCF2783F000DDE7CFB07E001AA17B83A3678A00EE24CBAE0B8F0C81FC006017D73983F800CB07C001BC4E1CE779FB83F000DE7EEB155C4E6D2C0
    0  14884 001010  4292392104000       36036000 07272F53 000001000197FFFB80000001B5854FF71A00000001011A6C04051B00000001021A6C04051B000000000001031A6C04051B000000000001041A6E6638449AC07D8810513B55358A275850554496222785DC6113598D7BE0256151D71D6690EB7C3AA1B2C0B49087F9FCBB8DE2E5B207C9640132747DCC5D23007A4E8B182F47D5
    0  11608 001018  4292320032000       36036000 4CEEFFDC 00000100011FFFFBB8000001B58324379A00000001011AAC04052B00000001021AAC04052B000000000001031AAC04052B000000000001041AAF5FE78D8547415E7DF221761F79E37F3807F00B627DE1D4AB07F001BC2AD57DE7899F4BB805F799697274BB474EFCFD4DE15633016C4EAEA7D06300199CD755042BEE13AB07F0
    0  11940 001018  4292356068000       36036000 E98B070F 00000100015FFFFBB8000001B58433371800000001011AAC04052B00000001021AAC04052B000000000001031AAC04052B000000000001041AA46E735CB01A5E6D8B8568EB07E001AEA6387DB5BD7326E15779B25D313EB8A9AA89E0E80035C6E678B00EE3EB8B89914441203FB6805F5D5CDE0B9A8FF9B33C1F8006C2ABA8C0
    0  17112 001010  4292500212000       36036000 4D6057F2 000001000257FFFB80000001B5854FF71800000001011A6C04051B00000001021A6C04051B000000000001031A6C04051B000000000001041A6E66161913B5427875FEE66805D055D611E279108F2A3C5DD752217A5542F8DC04AD4F952AE3189E103BD8400F6DA5DC77133B8F92A1ED71D509A5B0FD1632D72C5D534B49D853
    0  14628 001018  4292428140000       36036000 F86EE81A 0000010001DFFFFBB8000001B58334379800000001011AAC04052B00000001021AAC04052B000000000001031AAC04052B000000000001041AEFA4FAEA1D3AB8CC4C2B4DF0A00EAE0AF5CC4F07E001974F2EBB9A174E269C444CF356235CAA7E2EBAACA857A0BBC65C8B93C03B956137BE3A02E8E82C9F79E2690A99C53DC02F
    0  14984 001018  4292464176000       36036000 8DC869F3 00000100021FFFFBB8000001B58433379A00000001011AAC04052B00000001021AAC04052B000000000001031AAC04052B000000000001041AEFA4FBCF9CF4B01F57317274DC4007575D64B61F6F5DCD487D389AE626903C03F0670019807E7C0EA00321F5771101941774175CC4D563C547810D031800D75734E8E01F834800
    0  19480 001010  4292572284000       36036000 90E62B4D 0000010002D7FFFB80000001B5843FF79800000001011A6C04051B00000001021A6C04051B000000000001031A6C04051B000000000001041BA8757719CE791BF70E14D50DA02ADC4007541D7188DE14152E5FB989AC07D6A101D25807B4F71889E7E3C03B867101E7C2E9EE626930E41A6491A2B5D0D15EEE3A02D2049A0BA8
    0  13540 001018  4292536248000       36036000 62E34BE6 00000100029FFFFBB8000001B58333371A00000001011AAC04052B00000001021AAC04052B000000000001031AAC04052B000000000001041B5F7515F5CC9D75C67155DD202FAE735045E7AE22278593E50EA5CAA7191FC78A805D031800D774D5C172FC0FE003543F775AEF116661713A6A567044B757A32EAEAA55BA8AC1FC
    0  69224 000011  4292590302000       36036000 DCDE7A18 000001B32D01E034138823821020202620262C2C2C2C2C2C343034363636343434343636363A3A3A4444443A3A3A36363A3A404044444A4C4A464644464C4C50505060605C5C7070748A8AA6000001B51482000100000000000001B8086940C000000100000FFFF8000001B58FFFF79A00000001010B7E1F68D1A30C368D1A34
    0  61944 001010  4292698410000       36036000 1867D635 0000010000D7FFFB80000001B5843FF7980000000101126C04051B0000000102126C04051B00000000000103126C04051B00000000000104121044C340B004A30FC6834800C5818051FFE035C03881FC006C3EE3B1BB1C7F016049E440BD45FE497044FFC28DE3D0492280F06D9AC208D7108D97C61254FC0F0113E0620018E0
    0   4476 001018  4292626338000       36036000 E6D680EF 00000100005FFFFBB8000001B58334431800000001012AAC04052B00000001022AAC04052B000000000001032AA4E020294DC000000001042B5F52732996AE28647CEF3E602D89F4E3F3E4CCE7350BB680C95800000001052AAA1526DCA64D566AA72918749AC065339E8BA75A94F55EB69B949D49A173AA94C654DEEA35855E
    0   4464 001018  4292662374000       36036000 F27E81AB 00000100009FFFFBB8000001B58433331A00000001012AAC04052B00000001022AAC04052B000000000001032AA5C040529F0000000001042B5F5261C2866F66121778EC8CF5011BB4ACCD40C6E73AA1A81DEB452956A0D741D4390554640000000001052AAA615224C8D533AD53D569DA560766520E6ACD4C62750C5F54FDC5
    0  65260 001010  4292806518000       36036000 201E2A1B 000001000197FFFB80000001B5842FF71A0000000101126C04051B0000000102126C04051B00000000000103126C04051B00000000000104121044C9B8A70C241BC08ACF233B00AA26AD0389C002CC02E3E07F00182EEB95858ED83C0EDC6A364CCC007EB012209002B6208A272A40D02E288B000FAE730168071401100A9773
    0   5000 001018  4292734446000       36036000 36EEE581 00000100011FFFFBB8000001B58324339A00000001012AAC04052B00000001022AAC04052B000000000001032AA4E020294DC000000001042AA4329B0CA52CA09F0E1B9AE3A9CE696934E73EE9CE7DC7C06631D5539E6C2232839D0624A0AD78000001052AA91A69953EAD8509EF556CA6A554FA9269EAA8953272E5F4A6A548
    0   4884 001018  4292770482000       36036000 099FAA41 00000100015FFFFBB8000001B58433331800000001012AAC04052B00000001022AAC04052B000000000001032AAC04052B000000000001042AADA9541437BC1DCF60B0BAE06F342C7FA6E3EB9CE5D048ED545F4DC6D281DF89C4736C04F44A541553A000000001052A14257A155CF5E850CA330750A118D4F3525B5487D710C4
    0  69820 001010  4292914626000       36036000 611BB8C8 000001000257FFFB80000001B5844FF7180000000101126C04051B0000000102126C04051B00000000000103126C04051B00000000000104121044C0A809407020088938143FF2018B13070A389E07D403403D03F800C1770D46C9A76DC9E046BA7B9A71BD41E3B0A9C4AAE311B34A1F9812000C8F130844D480D9007D80B31F
    0   4936 001018  4292842554000       36036000 AB37BB4A 0000010001DFFFFBB8000001B58324339800000001012AAC04052B00000001022AAC04052B000000000001032AA4E020294DC000000001042AA56E9F46356253FD04B5B0E1B9F1D4E73D43E0D6C3ED09853F9F3DADF5E0B85864D71B54CA018A5C8A0C5941C80000000001052A1D24C9E61C33D4931F730E13583F800D2A4B84
    0   5184 001018  4292878590000       36036000 7F1AAC78 00000100021FFFFBB8000001B58332239A00000001012AAC04052B00000001022AAC04052B000000000001032AAC04052B000000000001042AAE51DA8B060A18FD5090BAD0932CE617E985FAE2E6A17E0BAE024EAC56BC4C1566499754FA82794D8D4191942A1CA7C0000000000001052A142489E94FC28628F003B01DA1524A
    0  59304 001010  4292986698000       36036000 63F1CC2C 0000010002D7FFFB80000001B5832FF7980000000101126C04051B0000000102126C04051B00000000000103126C04051B00000000000104121045C07603647FF619CD03C4E642C5AC5888868439F89DC28920747412807B001B8E899230A100465139A062FFF81FFFFEE1D13283CD1FF91D403480601A5A70CD9D63D3F1A003
    0   5060 001018  4292950662000       36036000 2A3A6E89 00000100029FFFFBB8000001B58323231A00000001012AAC04052B00000001022AAC04052B000000000001032AA5C040529F0000000001042AA26D4CC286D74A8DAA1DC753C270CEA85F0BB4895050A4D9DF5491DE9C566903090091215E1100000001052AA95848D206107191622B1A23406E9463550C61425EFA712D8D4E34
s=1 n=10 o=5996544
    1   1536 002001  4292213760000       34560000 6C1D652B 0B7717DC1C30E1DFE1CBC924A00007FE3FDA96A26462C0342C28282A8C008D12E1C121013C04362628BAB753AD2D784F9ED75692DAAA54AB52D6ED3257B6DCC385AFB6665832E484CF75BDE295CBEDF71EEC548E93F9B62C3974F613E850D541AF09ED895173DF8824883C6B0B71351BAB29A06B0EB574D7DFEAAE95E3AAD0A4
    1   1536 002001  4292248320000       34560000 4D394FB2 0B77FE0E1C30E1DFE1CBC924A00007FE1FDA96A2A4C2C0142C28282A8B808D11E18141017C3A30202EABB74C96B4052F953EACA9F3B7B0D53E7EA693E5509F3F74FF13B4EC338484E594D37EA6BBA7D0DFA57D1A1B622FDFB8AEF9D39A55ABBA7D06C268EE8CE455FA9875D38CE10A9BE7CF9D3E835D4975D39343A4F6C29AEA
    1   1536 002001  4292282880000       34560000 A8E7F391 0B77A1B41C30E1DFE1CBC924A00007FE1FDA96A305A320342C28282A8A800B1161B11102EC3E342820AAB80EFD2C37CFA9527549F41B899ED77CAA0D754ED1225362CD34E4D6C5676F95BEAEE74255361F4F4C337AA850E7297D59EEF86A9F3A764633E8FA29EB5913E814D4BE9095F5AA6F6BA67CA61BDD7497BAA5363C37D4
    1   1536 002001  4292317440000       34560000 007D0DDC 0B77D8FA1C30E1DFE1CBC924A00007FE1FDA96A2C24320542C2828268B8F0C10E19101012C3E2A24292AB74B4DD3E7C96E3F7445F3E7FF1A9BF7F09342B8FD551D74A157A35DF2A7CF9FA59D608A74109F427EF6DBE54FF3E0AE1D21B5EE3E86F6957CEADA5B9CFA6D6AE95DC37CE9F3EA69D043537D53E1A99385AD152B099D
    1   1536 002001  4292352000000       34560000 80FC05CD 0B77E3B81C30E1DFE1CBC924A00007FE1FDA96A322C380342C28282A898E8A916152F2D12C3C282226AAB74AFA1A67496B677C95FBE555AD434CF61BE7CE9ED77512CD55B9115AA4CFAB2B7D4DF3DA55A1BDAF0D4AAA4FD33F54E92BEA4F9F56D55DF2ACEE44A6F9B427CFABD2B0960C01AA702144B54C37EB9FAAA54E657AF4
    1   1536 002001  4292386560000       34560000 039E4497 0B77B76C1C30E1DFE1CBC924A00007FE1FDA96A322A340342C2C282A898C8B11E1A111116C002A2032AAB74C95F434B0D2D77CF9F26CE992BF7535F5B7CF93527EABBBD5890E1D6AD1EBAAAD4DD2A7B5E1A4B6F9F2A54AAB2B730D2D6A892C4D86E9F3E8E4AB856DFAA7ABABAAACFA9A5A699FA548F9F4286FA1A2735DD2AB71
    1   1536 002001  4292421120000       34560000 29117A8A 0B77EE881C30E1DFE1CBC924A00007FE1FDA96A24523201430282C2A898F8B13618181211C36342620AAB74A99F3FA4F6BBE7CE6DBE7EF9DA57B0DD3E7B0DCE77762CBE65F2135B74AD2DC7696B3F4B0DCD2AD5DD3B70F75D756833BE4B65C5C4B0A73FD4C2A86F9F4451ADFA672FA96A7D4ABBD56A9CA95F5DF3E7B469DBB09
    1   1536 002001  4292455680000       34560000 DEF0257F 0B7736D11C30E1DFE1CBC924A00007FE1FDA96A5C4E300343828282A970F8C11E16172F11C3634222AAAB7210F356A739F4274E9FB6549952AA6F52D75B59F43851253A5BB0A9C77696BBBA6988BDAEF75C2B706342A4FE13F42F9F29855EBBF72F9EDCCFD2AA50DFBEA699525ACFAB5A7E96BBD7D494C3855DCD84282B5E535
    1   1536 002001  4292490240000       34560000 2C4DEDA0 0B77AC3B1C30E1DFE1CBC924A00007FE3FDA96A564A2E034382C282A97800C91E19191216C023E2E2CBAB7410E157ACE9F537AFA9537B0AB584AF9D277ABD2C2851606A4EB7155C2161540763153A750DF3E7AFD542A499F5422966DB5361F527D0A9439AE4479715226AC362B72056565ADBE4EA932A7539FD1AEF6B3EA6A5D
    1   1536 002001  4292524800000       34560000 5D2CF2B4 0B77AB751C30E1DFE1CBC924A00007FE3FDA96A2A4A2E0342C282C2A8A800C11E18191112C083C2826AAB8189952AA4F6BD2A4FA1574D495A55D057AA80447217D1FB53592FDF5C534A22A7F5613F42EDF528509F2E7B0AC2A753613A750D53EAD5A93ECF13EAD713527EA69BA7AFA13F9CFE9254CA92BDB7112D74AA5F57E2F
s=2 n=0 o=24842240
mt=0000024391B6C880 n=3
s=0 n=1 o=342472704
    0  71036 000011  4293004716000       36036000 D525E957 000001B32D01E034138823821020202620262C2C2C2C2C2C343034363636343434343636363A3A3A4444443A3A3A36363A3A404044444A4C4A464644464C4C50505060605C5C7070748A8AA6000001B51482000100000000000001B8086946C000000100000FFFF8000001B58FFFF79A00000001010B7E1F68D1A30C368D1A34
s=1 n=1 o=5996544
    1   1536 002001  4292534736000       34560000 9ABFB7B4 0B77FC131C30E1DFE1CBC924A00007FE3FDA96A264A2A054302828268A808D10E1A161219C04362636B2B74B4ABA74CE6B42A4F77C29D0DEC38549F3E7CFA956A566F2065FC15C27E961D77D4D3264C99FA5A4ADCC27CFD32676A293E751D53F4CF61A5925575D6D539E70ABB574FABA4A7C2C1156C44B6E304442AC92A7CEA1
s=2 n=0 o=24842240
004047:0010 AV sync issue in stream 0 at 1:06:10.800 : video frame timecode differs by -6.706s
004047:0010 AV sync issue in stream 0 at 1:06:11.183 : video frame timecode differs by -6.589s
004008:0010 AV sync issue in stream 1 at 1:06:10.208 with duration of 6.784s : 212 frame(s) dropped to reduce audio skew to +22.8ms
004047:0010 AV sync issue in stream 0 at 1:06:11.567 : video frame timecode differs by -6.473s
004047:0010 AV sync issue in stream 0 at 1:06:11.951 : video frame timecode differs by -6.356s
004047:0010 AV sync issue in stream 0 at 1:06:12.335 : video frame timecode differs by -6.239s
004047:0010 AV sync issue in stream 0 at 1:06:12.718 : video frame timecode differs by -6.122s
004047:0010 AV sync issue in stream 0 at 1:06:13.102 : video frame timecode differs by -6.006s
004047:0010 AV sync issue in stream 0 at 1:06:13.486 : video frame timecode differs by -5.889s
004047:0010 AV sync issue in stream 0 at 1:06:13.569 : video frame timecode differs by -5.839s
004047:0010 AV sync issue in stream 0 at 1:06:13.853 : video frame timecode differs by -5.755s
004047:0010 AV sync issue in stream 0 at 1:06:14.236 : video frame timecode differs by -5.638s
004047:0010 AV sync issue in stream 0 at 1:06:14.620 : video frame timecode differs by -5.522s
004047:0010 AV sync issue in stream 0 at 1:06:15.004 : video frame timecode differs by -5.405s
004047:0010 AV sync issue in stream 0 at 1:06:10.099 : video frame timecode differs by -5.021s
005003:0000 Failed to save title 0 to file D:/Video/7000096713.1/B1_t00.mkv
005004:0080 1 titles saved, 1 failed
005037:0204 Copy complete. 1 titles saved, 1 failed.
Application exited at Sun Mar 03 22:14:20 2024
Mr. Red
Post by Mr. Red »
From the log:
MakeMKV can't read the second movie properly due to multiple read errors.
It seems the first error at offset 2002944 can be worked around but not the second one at offset 24563712.
If cleaning the disc doesn't help make a complete disc backup with MakeMKV (the second button in the toolbar before opening the disc). Then you can either open the folder directly in VLC (like you would with a DVD) or try to extract the missing movie from the VOB files.
