Jurassic Park (1) UHD rip error
SequenZz
Post by SequenZz »
I started using MakeMKV recently and was able to successfully rip about a dozen of DVD's, Blu-Ray's and UHD Blu-Ray discs without any issues except when i started ripping the "Jurassic World - Ultimate Collection" (All 6 UHD movies). I was able to rip "Jurassic Park 2+3" as well as "Jurassic World "1-3" without any issues but not "Jurassic Park 1".
For "Jurassic Park" i get an error after approx 45 GB or 5 min left (consistently):
Using LibreDrive mode (v06.3 id=FA108BB7DA63)
File 00800.mpls was added as title #0
Title #00020.mpls has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00077.mpls was added as title #1
File 00165.mpls was added as title #2
File 00164.mpls was added as title #3
Title #00006.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory Z:/media/movies/jurassic.park/jurassic.park(1993)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952638976'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53952638976'
DEBUG: Code 3221225628 at C')Ei;RW<@zk PamDG:213131502
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952706560'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53952706560'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952706560'
DEBUG: Code 100864261 at C')Ei;RW<@zk PamDG:213131502
DEBUG: Code 0 at 2lX"ugVv6{G6cHO6YIB):29395471
DEBUG: Code 0 at Kwj/.PShTdx quApj2.^:29394068
DEBUG: Code 0 at 2lX"ugVv6{G6cHO6YIB):213131157
DEBUG: Code 0 at 2lX"ugVv6{G6cHO6YIB):121262647
DEBUG: Code 26344095 at 2lX"ugVv6{G6cHO6YIB):121261773
DEBUG: Code 0 at ^,i~BX3is!O#bBE`7h\+r:213137068
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952774144'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53952774144'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952835584'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952903168'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53952970752'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53952970752'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53953622016'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53953689600'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53953953792'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53953953792'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53954150400'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53954605056'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53954605056'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '53954672640'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '53954672640'
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file Z:/media/movies/jurassic.park/jurassic.park(1993)/Jurassic Park_t00.mkv
Encountered 25 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Here is additional information about my drive and the disc:
Product: BD-RE BU40N
Revision: 1.04
Serial number: MO*******56
Firmware date: 2120-05-06 11:42
Highest AACS version: 76
Firmware version: 1.04
Disc Information
Label: JURASSICPARK_UHD_UPK3
Timestamp: 2018-04-03 13:30:23
Protection: AACS2.0/C v61
Data capacity: 58.82 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
After cleaning the disc 2 times I noticed what appears to be a tiny scratch but I'm not sure:
In that case i hope I can still return the disk, but I'm open for other help/suggestions!
Nucleus
Re: Jurassic Park (1) UHD rip error
Post by Nucleus »
Others may know of a more thorough cleaning procedure for potential scratches, but I highly recommend a pack of these microfibre cleaning cloths off Amazon- particularly for UHD ripping, as recommended to me by @asmcom
I soon ordered a pack after a rip failed after an hour or so - fingerprints I suspect. As you know UHD ripping involves a huge transfer of data so a few seconds wiping the disc beforehand is well worth it, also applies to brand new discs.
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
SequenZz
Post by SequenZz »
After cleaning the disc multiple times with all different techniques, including warm water with dishsoap and others, it eventually even failed after 5 GB. I was so devastated and thought I really fucked up. But I tried cleaning it a last time with 99% isopropyl alcohol and some cotton + microfiber and it suddenly went through! Don't know if it was a one time thing, didn't try it a second time but I'm so happy now!
