Conan The Barbarian 4K
satanikmekanik
Conan The Barbarian 4K dump submited.
EnochLight
Re: Conan The Barbarian 4K
Was it ever fixed? Just bought the collection and I'm in the process of attempting my first rip with Disc 1.
mwebb
I have the US Conan Chronicles set which I beleive is the same disc and this was working fine as of 20th February. Both films in fact.
EnochLight
Yeah I can confirm that everything ripped just fine (Arrow Video's The Conan Chronicles: Conan the Barbarian & Conan the Destroyer 4K Ultra HD set). Man, that additional content is hit or miss though quality-wise. A lot of blurred out watermarks that Arrow Video included, and many go right across the faces of the people in the interviews LOL!
I watched the first film last night (used Plex Media Server but watched on an Apple TV 4K (2nd gen) via Infuse Player, which is a far better quality player than Plex IMHO. I compared via the actual UHD Blu-Ray on my PS5. Video quality was indistinguishable to my eyes. And these films have NEVER looked so good and sounded so good before - I've waited 30+ years for this ever since I got the crappy DVD back in the 90's!
satanikmekanik
Yes, its working!
Antimer
I can't get it to work for me and I'm not good with this stuff.
It says:
MakeMKV v1.17.6 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.02 SIK9JH3SB265d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=62194E19F4EC)
Downloading latest HK to /Users/antimer/Library/MakeMKV ...
Saved AACS dump file as /Users/antimer/Library/MakeMKV/MKB20_v77_CONAN_THE_BARBARIAN_-_4K_UHD_FAE8.tgz
I'm not sure what to do
It says:
That indicates that your MakeMKV is having trouble downloading the latest hashed keys for decrypting. Try using a VPN.Antimer wrote: Sat Feb 24, 2024 2:09 am Downloading latest HK to /Users/antimer/Library/MakeMKV ...
Antimer
The VPN worked. Thanks for the helpThat indicates that your MakeMKV is having trouble downloading the latest hashed keys for decrypting. Try using a VPN.
ikomrad
Do you remember which title you chose for each disc? For Disc 1 of Conan the Barbarian , there were 3 titles around 80 GB in size. I chose the largest one which was 84 GB, and I''ll know in an hour or so if I chose correctly.EnochLight wrote: Wed Feb 21, 2024 3:18 pm Yeah I can confirm that everything ripped just fine (Arrow Video's The Conan Chronicles: Conan the Barbarian & Conan the Destroyer 4K Ultra HD set). Man, that additional content is hit or miss though quality-wise. A lot of blurred out watermarks that Arrow Video included, and many go right across the faces of the people in the interviews LOL!![]()
EnochLight
I actually ripped them all (I'm a digital hoarder). Can't remember the difference between them, though.ikomrad wrote: Wed Mar 27, 2024 2:49 am Do you remember which title you chose for each disc? For Disc 1 of Conan the Barbarian , there were 3 titles around 80 GB in size. I chose the largest one which was 84 GB, and I''ll know in an hour or so if I chose correctly.
ikomrad
I learned that it helps to read the back of the case. Conan the Barbarian Disc 1 has 3 versions of the movieEnochLight wrote: Wed Mar 27, 2024 11:44 amI actually ripped them all (I'm a digital hoarder). Can't remember the difference between them, though.ikomrad wrote: Wed Mar 27, 2024 2:49 am Do you remember which title you chose for each disc? For Disc 1 of Conan the Barbarian , there were 3 titles around 80 GB in size. I chose the largest one which was 84 GB, and I''ll know in an hour or so if I chose correctly.
1) Theatrical at 127 minutes
2) International at 129 minutes
3) Extended Cut at 130 minutes
I'm ripping the other 2 titles while I write this.
Then it's off to the Conan the Destroyer and finally the special features discs.
EnochLight
LOL! Yeah, it does. When I originally replied to you, I was nowhere near my studio nor the case. Glad you figured things out, though.
