Pioneer BDR-212DBK vs BDR-212V
NotaNumber
Post by NotaNumber »
Hi Everbody
I'm interested in ripping Blu-ray 3D to view on my VR headset. Since I currently do not have a 4K UHD setup (other than my VHD) 4K is not a priority.
Does anybody know what the difference is between the Pioneer BDR-212DBK and the BDR-212V? The specs look identical on the Pioneer website. Is it just the packaging?
Re: Pioneer BDR-212DBK vs BDR-212V
Same drive different letters and fw name
Email me for the flasher see below for email and price
212v firmware is special to do burning result quality checks.
NotaNumber
Thanks for the replies.
Further research tells me that in DBK, D means the drive does not support DVD-RAM media and BK is for Black front piece color. I would guess there is also White and Grey/Putty colors available.
V stands for VinPower, a manufacturer/seller of duplication towers and software. The firmware is customized for over burning and more error checking. The latest version of VinPower's firmware for the Pioneer 212 is v1.02 showing a file date of 09/27/2022.
From what I gather from posts elsewhere v1.02 can still be flashed/crossflashed. I ordered one from Amazon. Let's see what firmware version I get and if it can be flashed.
The prices on 212s has been creeping up since I started looking at them 3rd quarter last year by $15-20.
Thanks again.
Send me a PM
Check PM.
NotaNumber
Drive arrived yesterday. May 2022 mfg date - ver.1.01 firmware.
@Coopervid Got your PM, thanks, reviewing now.
NotaNumber
Correction, March 2022 mfg date.
Anyway, thanks to @Coopervid I was able to cross-flash the drive. Wanted to use the drive a bit to see if it was problem free. Probably be difficult to return it with a cross-flashed firmware.:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number: -redacted-
Firmware date: 2022-03-07
Highest AACS version: 81
Drive platform: RS8F01
Firmware version: 1.02/ID43
Disc Information
Label: 2001_ A Space Odyssey
Timestamp: 2018-09-06 12:02:30
Protection: AACS2.0/C v65
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Now LibreDrive is enabled and I am able to backup UHD discs. Not that it matters but I noticed the drive now supports DVD-RAM media which it didn't before with the 212V v1.01 firmware.
Note to all: Don't be too hard on newbies for not answering PMs. As a new member one has to go through a brief probation period (min number of posts) before one can PM or reply to PMs.
hoops10
Post by hoops10 »
Check PM. Thanks
petrob
Post by petrob »
Following this thread, I purchased a used BDR-212V drive with a Feb 2022 date on the label but with firmware date showing as May 2022 in MakeMKV (still good).
Firmware revision is 1.02. That means I can crossflash this drive to be able to read UHD discs, right?
Can somebody help me with the procedure?
Thanks for the help!
petrob wrote:
Wed Apr 03, 2024 6:30 pm
Read your PM.
zaqqaz6917
Post by zaqqaz6917 »
Just want to thank Cooper who helped me with updating the FW on this drive to make it a Libredrive
Big thanks
Edit to add
This drive maybe the only pioneer drive currently available off the shelf retail new to be able to enable Libredrive for UHD purposes.
It seems Amazon USA and Canada have a prime seller with plenty of stock at fw 1.02 at a very reasonable 80 bucks, even though outside of drive is is labelled Feb 2024, so don't get put off by data on outside of drive till you actually have Makemkv analyze it
fs9178
Post by fs9178 »
@Coopervid Also interested in this fimrware upgrade. Can you PM me? Thanks !
changshi
Post by changshi »
@Coopervid I'm also interested in BDR-212V firmware upgrade.I'm new to makemkv,can you send me a PM?Thankyou!
Please post your Makemkv info to make sure you own this drive model.
