questinghero
Post
by questinghero » Tue Jan 23, 2024 9:20 pm
I was able to get it working, but it takes some effort. These instructions are for Windows.
- Edit the host file on your computer (C:\Windows\system32\drivers\etc\hosts) and add the following line to the bottom of it. I got the IP address from this post viewtopic.php?p=141837#p141837. You will need to open Notepad as Administrator to edit the hosts file.
185.84.108.20 hkdata.crabdance.com hkdata.fairuse.org
- Open up a web browser (Chrome/Edge/Firefox) and download the following file
- copy the sdf.dat.gz file to your makemkv data folder (should be C:\Users\username\.MakMKV)
- Start MakeMKV, and the disk will be decrypted.
This is what I did, and my UHD disk is now ripping... it is also possible that the issue is just fixed and I did nothing
Someguy1234
Post
by Someguy1234 » Wed Jan 24, 2024 2:38 pm
questinghero wrote: ↑Tue Jan 23, 2024 9:20 pm
For hosts file did you put a # and some space before that bottom line entry? I tried this and the disk I'm trying to rip still won't decode. It could be that it's not been fixed yet.
Also, I do have this in proxy server in MakeMKV.
questinghero
Post
by questinghero » Wed Jan 24, 2024 3:48 pm
Someguy1234 wrote: ↑Wed Jan 24, 2024 2:38 pm
Putting a # at the beginning of the line, makes it a comment and all the lines with # are ignored. It should NOT have a # at the beginning. I removed the Proxy line, as I don't think it was working. were you able to download the file from the website?
Someguy1234
Post
by Someguy1234 » Wed Jan 24, 2024 3:55 pm
I was able to download the file but I couldn’t decode (open) the latest DC animated film on 4K. I had submitted the dump file via svq email. When I remove the proxy it tries to check but fails, still. It could be AVG antivirus and its advanced firewall. I have two discs I’ve submitted dump files for and neither yield a successful result when proxy is removed or there. It only tries to check when proxy isn’t in makemkv settings. It seemed to all really happen after the latest version was installed. Nothing changed with my antivirus.
Someguy1234
Post
by Someguy1234 » Sat Jan 27, 2024 8:43 pm
I'm still getting a failure to update. Is anyone else still having this issue? I've allowed the hosts file to be updated, even switched antivirus software, and went entirely without. But nothing works, still..
Downloading latest HK to D:/MakeMKV ...
charnathan
Post
by charnathan » Sat Jan 27, 2024 9:18 pm
Someguy1234 wrote: ↑Sat Jan 27, 2024 8:43 pm
I'm still getting this error with both Avatar Collectors Editions.
Post
by dcoke22 » Sun Jan 28, 2024 12:54 am
The blocking might be happening at your ISP and outside of your control. The only thing that's worked for some people is to use a VPN to 'escape' from their ISP's network. They sometimes have to pick different exit points for the VPN before finding one that works.
Fortunately, MakeMKV saves the downloaded hashed keys, so you would only have to use the VPN whenever MakeMKV needs to download new keys.
Someguy1234
Post
by Someguy1234 » Sun Jan 28, 2024 6:12 pm
dcoke22 wrote: ↑Sun Jan 28, 2024 12:54 am
It's so strange you suggested this. I just tested something that uses this theory. I made a hotspot on my iPhone and used it as my Wifi. It allowed me to download the latest. See for yourself. It downloaded and didn't fail for once. The disc can't be decoded yet, but I've submitted the dump file.
Saved AACS dump file as D:/MakeMKV/MKB20_v77_Kindergarten_Cop_BEAC.tgz
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
UPDATE: It worked. I was able to now decode a disc I previously couldn't because of this download issue. It's certainly worth noting that I'm running the free AVG VPN on my iPhone. So, it is my ISP blocking it. I don't have any anti-virus software or a VPN on my PC right now. I'm going to be using a VPN on PC it looks like from now on. Does anyone know of a good free VPN for PC?
Rupert Pupkin
Post
by Rupert Pupkin » Sun Jan 28, 2024 7:58 pm
Something is definitely going on with Make MKV . All of my downloads are failing. I have tried 4 discs. Anyone have any real answers? I am going to be forced to go back to AnyDVD
charnathan
Post
by charnathan » Sun Jan 28, 2024 11:38 pm
Rupert Pupkin wrote: ↑Sun Jan 28, 2024 7:58 pm
I ended up getting Avatar Extended Collector's Edition to work by using my cell phone's internet as a hotspot like Someguy1234 mentioned. But you're right, something is going on since I was able to get Titanic to work on my home ISP. And there's like a week or two difference between that and the Avatar release.
Someguy1234
Post
by Someguy1234 » Mon Jan 29, 2024 1:33 am
LOL. Use a VPN like I said, Brian. I know it might hurt to do something I said to do but it worked. Not a fan of the podcast(s).
Someguy1234 on Mon Jan 29, 2024 1:39 am, edited 1 time in total.
Someguy1234
Post
by Someguy1234 » Mon Jan 29, 2024 1:35 am
charnathan wrote: ↑Sun Jan 28, 2024 11:38 pm
Great to hear it worked for someone willing to listen.
Puppy1980
Post
by Puppy1980 » Sat Feb 03, 2024 11:02 pm
I think Xfinity is definitely up to something. I couldn't get Titanic 4K to open, but the moment I turned on my VPN it worked like a charm.
Someguy1234
Post
by Someguy1234 » Sun Feb 04, 2024 9:21 pm
Puppy1980 wrote: ↑Sat Feb 03, 2024 11:02 pm
Yeah the ISPs are blocking it for sure. VPN is the only solution.
