Problem w/theatrical cut for Lady Vengeance from Arrow Video's Vengeance Trilogy Blu-ray Set
awookieewarrior
Post by awookieewarrior » Fri Feb 02, 2024 8:44 pm
Hi all, my issue is regarding the the Lady Vengeance Blu-ray disc from Arrow Video's Vengeance Trilogy set (region b).
MakeMKV displays two feature length options so I downloaded both. However, both are commentaries.
Name: LADY VENGEANCE
Source file name: 00024.mpls
Duration: 1:55:08
Chapters count: 12
Segment count: 1
Segment map: 31
File name: LADY VENGEANCE_t01.mkv
Source file name: 00000.mpls
Duration: 1:55:08
Chapters count: 12
Segment count: 1
Segment map: 4
File name: LADY VENGEANCE_t02.mkv
Does anyone know why this is? Am I doing something wrong? I wiped down the disc with a microfiber but no change.
Re: Problem w/theatrical cut for Lady Vengeance from Arrow Video's Vengeance Trilogy Blu-ray Set
Post by dcoke22 » Fri Feb 02, 2024 10:23 pm
https://www.arrowfilms.com/the-vengeanc ... 11605.html & https://www.dvdcompare.net/comparisons/ ... id=15553#9
^ Those suggest there should be DTS-HD Master Audio as well as 3 commentary tracks.
Can your playback setup play DTS audio?
Do you have a preferred language set in MakeMKV and perhaps it skipped the Korean language tracks?
The utility MediaInfo can show you a lot of details, including audio tracks, about .mkv files.
zeuspaul
Post by zeuspaul » Fri Feb 02, 2024 10:46 pm
I encountered a similar issue with Amazing Spiderman 2. Using HandBrake the audio was commentary. Using dBpoweramp with the same MakeMKV file I got the correct audio track. I never figured out why but moved on because I got what I wanted using dBpoweramp.
