Failed to open disk
johnceri
Failed to open disk
Post by johnceri » Fri Feb 02, 2024 12:25 pm
Hi seeking to make an mkv I got this in the Debug log.
The DVD plays normally - any ideas?
Debug log started at Fri Feb 02 12:19:26 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\JohnCeri/MakeMKV_log.txt
No SDF v098: ASUS_DRW-24D5MT_2.00_201906171049_KMJK32G1642
No auto SDF v098: ASUS_DRW-24D5MT_2.00_201906171049_KMJK32G1642
DEBUG: Code 0 at JH[R]Q46'ck{tMypQ:29396253
DEBUG: Code 0 at SM@e63jNU)cu"$Qt:213136746
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF id v098: ASUS_DRW-24D5MT_2.00_201906171049_KMJK32G1642
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
001003:0020 DEBUG: Code 0 at rsi1O0~:)@a]=L:29400071
003042:0000 IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
001003:0020 DEBUG: Code 0 at l+syVi Fz3cFvNC+^:121262854
Application exited at Fri Feb 02 12:19:58 2024
Re: Failed to open disk
Post by dcoke22 » Fri Feb 02, 2024 10:52 pm
MakeMKV has different opening modes for DVDs. Maybe one of them will work.
johnceri
Post by johnceri » Sat Feb 03, 2024 11:40 am
Thanks for coming back to me.
I have tried each opening in turn - the same result each time.
Other disks work fine. Not a big deal but would be interested to know what is going on.
John
johnceri
Post by johnceri » Sat Feb 03, 2024 11:43 am
Was going to add
Label: MR_HOLMES
Timestamp: 2015-08-24 12:10:47
Protection: CSS/CPPM
Data capacity: 7.19 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
This is what is reported on the disk.
dvdtuber
Post by dvdtuber » Wed Mar 05, 2025 11:59 pm
I never had this issue but I once had a disc that never finished scanning with increasing ETA but I could open it manually and I then just entered the chapters of interest and everything went smoothly from there. You could try it out if that works for you.
https://www.makemkv.com/manualdvd/
