Disk (not just BD) Open / Rip Failures (WH16NS40 1.05 iSCSI) - Good Disks / Drives. Faulty SCSI commands? Faulty Flash?
wackywayaroundit
#1 Post by wackywayaroundit » Fri Jan 26, 2024 11:00 pm
I don't really know where to put this because the issue is an error report, but is not related to a specific media type, and the drive itself is completely functional including for UHD.
The issue seems to be that this drive cannot complete the key exchange for any media types, but only over iSCSI and only this drive (two others are fine), and I don't seem to be able to flash it to the recommended firmware for UHD from linux either (I haven't tried Win11 SDFTool Flasher 1.3.5 yet, I'd have to yank the drive and put it into a windows machine afaik)
Anyway, I think this is a bug in which / how SCSI commands are sent to this particular drive and I'm wondering if there is a workaround or if this is something a fix may exist for.
Apologies in advance for tersity and/or tone of the info dump below, I certainly don't intend anything untoward. Hopefully, I've also not completely missed something already asked and answered, as I've done a fair amount of searching and reading and this particular case doesn't seem to have come up before.
Drives:
  1. BD-RE ASUS BW-16D1HT (works) /dev/sr1 => /dev/sg4
  2. BD-RE PIONEER BD-RW BDR-S13U 1.03 (works) /dev/sr0 => /dev/sg1
  3. BD-RE HL-DT-ST BD-RE WH16NS40 1.05 (drive at issue) /dev/sr2 => /dev/sg8
Target Configuration:
<direct-store /dev/sg{1,4,8}>
    device-type pt
    bs-type sg
    removable 1
</direct-store>
Client Configuration:
Standard MS iSCSI initiator, picks up all targets.
Context:
  • LG Drive (drive 3) has region code set to 1 (no idea when this happened, this drive is ancient)
  • ASUS (drive 1) and LG (drive 3) are both flashed for LibreDrive, and that is verified to work on multiple UHDs w/o iSCSI, but I don't know if that is related because I hadn't configured iSCSI before the flash. Pioneer is a no-flash-required drive.
  • All disks fail on LG drive (drive 3) (have not tried to burn my own w/o CP, but can) (see code block 1 below)
  • All disks open and rip correctly under identical iSCSI circumstances on different drives (drives 1 & 2)
  • All disks open and rip correctly using makemkvcon on the machine the drives are installed in and on all drives (see code block 2 below, though I don't see anything useful)
  • SCSI Error:
    Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0
  • Other errors:
    003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
    003332:0000 Saved AACS dump file as file://C:\Users\xxx/.MakeMKV/MKB_v12_Battlestar_Galactica-_Razor_0E88.tgz
    003303:0000 The volume key is unknown for this disc - video can't be decrypted
  • Local LG and remote ASUS open of 24 Season 3 Disk 4 seem fine (see code block 3 below)
  • Remote LG Open Shows error 'has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.' (code block 4 below)
  • Local LG Read of disk 4 works (see code block 5 below)
  • Remote LG Read of disk 4 fails with error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '4096' (see code block 6 below)
  • Remote LG Read of disk 4 with remote makemkv still running and with the disk opened (ala code block 4) SUCCEEDS AFTER LOCAL LG READ OF THE SAME DISK
  • Remote LG Open of Razor with remote makemkv still running doesn't succeed like the DVD does, but the disk cannot be opened to get to the right place. (code block 7)
  • SDF Tool works only sometimes (code block 8 / 9)
Code Block 1 (BD - Battlestar Galactica - Razor open failure):
Debug log started at Fri Jan 26 21:18:43 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\xxx/MakeMKV_log.txt
Using 1048320KB for read cache.
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF  v098: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_!SN!
001003:0020 DEBUG: Code 4279398400 at JH[R]Q46'ck{tMypQ:121264878
DEBUG: Code 0 at JH[R]Q46'ck{tMypQ:213132882
DEBUG: Code 1 at JH[R]Q46'ck{tMypQ:213132882
DEBUG: Code 2 at JH[R]Q46'ck{tMypQ:213132882
DEBUG: Code 3 at JH[R]Q46'ck{tMypQ:213132882
DEBUG: Code 4 at JH[R]Q46'ck{tMypQ:213132882
DEBUG: Code 5 at JH[R]Q46'ck{tMypQ:213132882
DEBUG: Code 0 at JH[R]Q46'ck{tMypQ:213133181
DEBUG: Code 0 at SM@e63jNU)cu"$Qt:213136746
SDF  v098: PIONEER_BD-RW___BDR-S13U_1.03_!SN!
SDF  v098: ASUS_BW-16D1HT_3.10_211901041014_!SN!
DEBUG: Code 2147483648 at WKYQi`r2nRn]/W8S:121265499
DAFD=PAAAADAAAAEABDQkEFwECAQ==
001003:0020 DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130582
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121263429
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:213130789
001003:0020 DEBUG: Code 1 at a%48&'jm4Zb*$m{*oY:213130789
001003:0020 DEBUG: Code 2 at a%48&'jm4Zb*$m{*oY:213130789
001003:0020 DEBUG: Code 3 at a%48&'jm4Zb*$m{*oY:213130789
001003:0020 DEBUG: Code 4 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130306
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121264395
001003:0020 DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213132721
001003:0020 DEBUG: Code 0 at g1G,9/u[_c:!rg}]:213131341
Application exited at Fri Jan 26 21:35:27 2024
Code Block 2 (BD - Battlestar Galactica Razor - Open / Read Success):
# makemkvcon mkv dev:/dev/sr2 1 .
MakeMKV v1.17.6 linux(x64-release) started
<snipped and reordered for brevity>
Title #???.mpls has length of ?? seconds which is less than minimum title length of 120 seconds and was therefore skipped
File ???.mpls was added as title #??
Title #???.m2ts has length of ?? seconds which is less than minimum title length of 120 seconds and was therefore skipped
File ???.m2ts was added as title #??
Saving 1 titles into directory file://.
1 titles saved
Copy complete. 1 titles saved.
Code Block 3 (DVD - 24 Season 3 Disk 4 - Open Success, minor differences including switch to windows for remote ASUS but otherwise looks the same):
makemkvcon info dev:/dev/sr2
Title #1 was added (18 cell(s), 0:44:01)
Title #2 was added (19 cell(s), 0:43:41)
Title #3 was added (20 cell(s), 0:43:29)
Title #4 was added (20 cell(s), 0:42:57)
Title #5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Total 4 titles
Code Block 4 (DVD - 24 Season 3 Disk 4 - Open Success LG):
Drive BD-RE HL-DT-ST BD-RE WH16NS40 1.05 !SN! has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Code Block 5 (DVD - 24 Season 3 Disk 4 - Local Read Success LG):
Saving 4 titles into directory file://.
4 titles saved
Copy complete. 4 titles saved.
Code Block 6 (DVD - 24 Season 3 Disk 4 - Remote Read Failure LG):
DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:29395241
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '4096'
DEBUG: Code 101019395 at C')Ei;RW<@zk PamDG:213131502
DEBUG: Code 1 at PkAKc'o[Z}/:jDB!:121262578
DEBUG: Code 0 at >%$uPZ?5K#4V -":213138494
DEBUG: Code 0 at /u`0WKB|YXK!?|:213134676
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '4096'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '4096'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '4096'
Code Block 7 (Remote Razor Open while Local Read in progress):
Code Block 8 (sdftool info, local to the drive, works *blank lines removed):
# sdftool -d /dev/sr2 --info
SDF.bin version: 0x0098
Drive Tool SDF not present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
8107:Patched (microcode access re-enabled)
8003:Firmware version
:1.05
8005:DVD all regions
8100:Yes
8006:BD raw data read
8100:Yes
8007:BD raw metadata read
8100:Yes
8009:Unrestricted read speed
8100:Yes
[Drive Specific SDF] Embedded Status Message:
8099:Using LibreDrive mode (v%1 id=%2)
:06.3
:7FC45AF98B4B
Identification SDF present
Code Block 9 (sdftool flash doesn't work):
# sdftool -v -v -v -d /dev/sr2 flash -i ~/drivefw/LG\ 5.25\ desktop/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Found sdf.bin version 0x98 at /root/.MakeMKV/_private_data.tar
Loaded SDF.bin version 0x98
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Re: Disk (not just BD) Open / Rip Failures (WH16NS40 1.05 iSCSI) - Good Disks / Drives. Faulty SCSI commands? Faulty Fl
#2 Post by dcoke22 » Sat Jan 27, 2024 3:31 pm
The recommended firmware for WH16NS40 drives is WH16NS60 1.02MK.
Ultimate UHD Drives Flashing Guide
I have no idea if it will fix the issues you're having, but getting the drive to the recommended firmware seems like the problem to try to solve first.
wackywayaroundit
#3 Post by wackywayaroundit » Tue Jan 30, 2024 4:15 pm
Thanks dcoke, I was afraid this might have to be my next step.
I pulled the drive and flashed it to 16NS60 1.02MK and verified that it can read DVDs, BDs, and UHD, without errors like the RPC and key/ex errors. But... This is now local to another machine through a UASP adapter, so I'll need to be able to reboot the original machine, which is running an uninterruptible batch job and will be for a few weeks still, before I can actually test (unless someone knows how to retrain, w/o rebooting, Linux to read the new firmware of the drive instead of sending every process that interacts with it into D+/Ds forever). My second child was also born since I posted that first thing, so I'm a little preoccupied.
Extra details from the flash here, although I think this looks exactly as it should:
# makemkvcon f -d /dev/sr2 rawflash main -i drivefw/LG\ 5.25\ desktop/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211
810291936.bin
Reading input file drivefw/LG 5.25 desktop/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLZK3693647
yes
 100% Operation finished
Done successfully
Info Pane:
Drive Tool SDF present
8013:Status
8105:Enabled
8001:Drive platform
:MT1959
8002:Firmware type
:1.02
8100:Yes
8100:Yes
8100:Yes
8100:Yes
:06.3
:7FA2657C7667
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :HL-DT-ST:BD-RE  WH16NS60 1.02:NM00100:-
wackywayaroundit
#4 Post by wackywayaroundit » Tue Jan 30, 2024 4:44 pm
Actually, scratch that reboot query in my last, and turns out you were right and this is exactly what was required... It occurred to me that the only thing I actually needed to do was plug the drive back into the machine through the UASP connector to get it into a testable state w/o rebooting. Opens/Reads/Rips over iSCSI now, go figure, I guess 1.05 is buggy as hell over iSCSI. All the more reason to flash to recommended.
Guess this can serve as a guide for anyone else who runs into this.
Thanks again!
#5 Post by dcoke22 » Wed Jan 31, 2024 1:06 am
Congrats on the new kid!
