My idea is to edit subtitles, so that only the forced subtitles show. I only have the subtitles which show everything.
So far I figured out how to extract the subtitles I want to edit with „gMKVExtractGUI“ and with „MKVToolnix“ I can merge the files.
I used „Subtitle Edit“ to open the given subtitles, then I click on „show only forced subtitles“ and I use the export function to export as a „.sup“ file.
After merging, for some reason the new subtitles will not show up (I‘m using the VLC player).
What did I do wrong? Do I have to make adjustments in the window which says „Blu-ray SUP“ where I can tweak image settings? (I did not change anything before exporting)
Thanks in advance for your help!
Subtitles not showing
Nucleus
Re: Subtitles not showing
See Mux/Remux: Set A Subtitle Stream On By Default (Forced) link in my sig. This one.StarryNight wrote: Sun Jan 28, 2024 4:15 pmAfter merging, for some reason the new subtitles will not show up (I‘m using the VLC player).
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
StarryNight
Thanks for your help! It works now
