Is this drive flashable? I think not, but it doesn't hurt to ask.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CEDL011924UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Firmware version: ID05
Pioneer BDR-XS07U Flashability
Re: Pioneer BDR-XS07U Flashability
No. Firmware younger than Dec. 2022.
Thanks, man!
Do you now if this will always be the case (i.e., it's impossible) or is it being worked on?
It's been worked on more than a year. So chances are low.
I see. Thanks for the info.
Just purchased a BDR-XS07U with the same firmware. Any updates on flash-ability?
Is there anything I can provide to help with the progress?
Nope.
