Pioneer BDR-XS07U Flashability
drxenos
Post by drxenos »
Is this drive flashable? I think not, but it doesn't hurt to ask.
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CEDL011924UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Firmware version: ID05
Re: Pioneer BDR-XS07U Flashability
No. Firmware younger than Dec. 2022.
drxenos
Post by drxenos »
Thanks, man!
Do you now if this will always be the case (i.e., it's impossible) or is it being worked on?
It's been worked on more than a year. So chances are low.
drxenos
Post by drxenos »
I see. Thanks for the info.
Phishly
Post by Phishly »
Just purchased a BDR-XS07U with the same firmware. Any updates on flash-ability?
Is there anything I can provide to help with the progress?
Phishly wrote: Sat Mar 09, 2024 9:28 pm Just purchased a BDR-XS07U with the same firmware. Any updates on flash-ability?
Nope.
