Green Bar and Off Colors
KingStewart
Post by KingStewart »
When I play some of the Blu-Rays I've ripped there is a Green Bar at the top of the video and the colors appear off.
Attached is an example of this issue.
Is there any way to correct this problem? Thanks
Re: Green Bar and Off Colors
Whatever picture you posted didn't seem to make it. But MakeMKV does a pretty good job of copying exactly what's on the disc. It might be something with your playback setup that's giving you troubles.
KingStewart
You just have to disable Hard Drive Acceleration in Preferences → Input & Codecs → Codecs and it should solve your problem. 8)
KingStewart
Wow! That really worked. Thanks homie.
janegleichner
Post by janegleichner »
KingStewart wrote: Wed Sep 04, 2024 2:44 pm You just have to disable Hard Drive Acceleration in Preferences → Input & Codecs → Codecs and it should solve your problem. 8)
I fixed it thank you very much
