Cannot get Ocean's Thirteen DVD to read properly on multiple drives. Before I try another disc (if I can find it), I hope someone can offer any other suggestions. Obviously Title #1 is the one I'm after.
Auto Mode:
MakeMKV v1.17.6 win(x64-release) started
Downloading latest SDF to C:\Users\xxxxxxx/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Signature is invalid in IFO file
Title #1 (2:01:59) was skipped due to navigation error
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (1 cell(s), 0:22:46)
Title #7 was added (1 cell(s), 0:04:34)
Cells 7-7 were removed from title end
Title #8 (0:08:17) was skipped due to navigation error
Title #9 in broken titleset was skipped
Audio stream #4 looks empty and was skipped
Subtitle stream #10 is identical to stream #8 and was skipped
Subtitle stream #11 is identical to stream #8 and was skipped
CellFull mode:
Calculated BUP offset for VTS #3 does not match one in IFO header.
IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 was added (34 cell(s), 2:01:44)
Title #8 declared length is 0:08:16 while its real length is 0:01:13 - assuming fake title
Saving 1 titles into directory C:/Video/OCEANS THIRTEEN
Failed to save title 0 to file C:/Video/OCEANS THIRTEEN/OCEANS THIRTEEN_t00.mkv
0 titles saved, 1 failed
The "Failed to save title" message came rather quickly after starting, within 30 seconds. I also tried DVD Decrypter in both IFO mode and ISO mode.
dare2be
Re: Ocean's Thirteen DVD
Additional info: both DVD Decrypter and VLC fail at the same spot, cell/chapter 20 of title 1.
My standalone Blu-ray player plays it just fine.
