LibreDdrive, Ubuntu, LG WP50NB40
danielrosehill
- Contact:
Greetings good people of the forum!
Stumbled here - like many I assume - via the datahoarders sub.
I've been using an LG WP50NB40 for the past couple of years to create BD-R M-discs for archival purposes (creating them using K3B on Ubuntu Linux).
Everything was going fine until the burner decided it was done creating Blu Rays!
I'm intrigued by what I might be able to achieve by flashing LibreDrive onto the hardware and as it's soon to be almost totally useless to me (I have a new BR burner on the way), I don't mind taking the risk of bricking the thing.
My only question is whether anybody happens to have undertaken flashing this onto this particular product before? The only firmware listed for the product on the LG site is for a different UPC code. But again ... I'm not too adverse to taking the risk that this thing will become an expensive doorstopped.
Any tips or pointers appreciated. I'm a longterm Ubuntu user but a noob at mucking around with optical drivers - at least beyond what you see with K3B
Re: LibreDdrive, Ubuntu, LG WP50NB40
Ultimate UHD Drives Flashing Guide
^ The first post of that thread is maintained and has all the flashing instructions and links necessary.
This post: viewtopic.php?p=129698#p129698 says the WP50NB40 is the same as the BP50NB40.
danielrosehill
- Contact:
Thank you much!dcoke22 wrote: ↑Wed Jan 24, 2024 7:04 pmUltimate UHD Drives Flashing Guide
audireddevil
Bought a WP50NB40 and did the sdftool and followed the instructions but still the drive won't read a 4k uhd. I've tried multiple USB ports and discs. Any ideas?
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK0AN4SB0632
Highest AACS version: 16
Firmware version: 1.03
Revision: 1.03
you only did half you need to go to BP60NB10 or BU40N to read UHD see guide belowaudireddevil wrote: ↑Sat Jan 27, 2024 2:30 amBought a WP50NB40 and did the sdftool and followed the instructions but still the drive won't read a 4k uhd. I've tried multiple USB ports and discs. Any ideas?
Revision: 1.03
you haven't followed the instructions. You have done the first flash. Now you need to do the cross-flash.audireddevil wrote: ↑Sat Jan 27, 2024 2:30 amBought a WP50NB40 and did the sdftool and followed the instructions but still the drive won't read a 4k uhd. I've tried multiple USB ports and discs. Any ideas?
Revision: 1.03
audireddevil
I'm sorry, I thought I did. I did the DE_LG_BP50NB40-NB50_1.03_MK.bin and then did the DE_LG_BP60NB10_1.00_MK.bin firmware update and after that didn't do anything then tried the DE_LG_BU40N_1.03_MK.bin and nothing. Not sure what I'm doing wrong at this point. Bluray rip just fine but I can't get the drive to read UHD. Thanks.
read the guide we cant give everyone personalized helpaudireddevil wrote: ↑Sat Jan 27, 2024 4:19 amI'm sorry, I thought I did. I did the DE_LG_BP50NB40-NB50_1.03_MK.bin and then did the DE_LG_BP60NB10_1.00_MK.bin firmware update and after that didn't do anything then tried the DE_LG_BU40N_1.03_MK.bin and nothing. Not sure what I'm doing wrong at this point. Bluray rip just fine but I can't get the drive to read UHD. Thanks.
i do offer an auto flasher for this drive marty may too check our selling posts
audireddevil
so i did the left screenshot and then the right one. Thought that was correct...
https://imgur.com/a/x037hcL
All I can say is follow the guide works for me.l and thousands of others me and Marty to it different but both work it followed.audireddevil wrote: ↑Sat Jan 27, 2024 12:54 pmso i did the left screenshot and then the right one. Thought that was correct...
Soon the guide will get more complicated
audireddevil
Yeah, the guide looked pretty straight forward and I thought I was doing the right stuff. I did email you directly about doing a remote flash, too.
Yes and you would not tell me your drive letter so I could not help you the email states I need the drive letter you sent me cdrom0audireddevil wrote: ↑Sat Jan 27, 2024 2:23 pmYeah, the guide looked pretty straight forward and I thought I was doing the right stuff. I did email you directly about doing a remote flash, too.
audireddevil
Oh, sorry. I just copied and pasted what was in the right side of my makemkv like you highlighted in that picture. I'll do a screenshot later
audireddevil
i emailed you a screenshot just now of makemkv if you can still help...Billycar11 wrote: ↑Sat Jan 27, 2024 2:29 pmYes and you would not tell me your drive letter so I could not help you the email states I need the drive letter you sent me cdrom0audireddevil wrote: ↑Sat Jan 27, 2024 2:23 pmYeah, the guide looked pretty straight forward and I thought I was doing the right stuff. I did email you directly about doing a remote flash, too.
Sent over the flasher shortly after I got the emailaudireddevil wrote: ↑Sat Jan 27, 2024 11:42 pmi emailed you a screenshot just now of makemkv if you can still help...Billycar11 wrote: ↑Sat Jan 27, 2024 2:29 pmYes and you would not tell me your drive letter so I could not help you the email states I need the drive letter you sent me cdrom0audireddevil wrote: ↑Sat Jan 27, 2024 2:23 pmYeah, the guide looked pretty straight forward and I thought I was doing the right stuff. I did email you directly about doing a remote flash, too.
