Ripping just selective m2ts segments?
rjbell4
Post by rjbell4 » Sat Jan 26, 2013 3:49 am
I like how MakeMKV shows me the segment map for each title. When there are several titles which could each potentially be the one I want, I can easily compare the titles and see what segments are different.
However, what I'd really like to do at that point is just select the particular segments to rip. For example, if one title is segments 1.m2ts, 2.m2ts and 3.m2ts, and another is 1.m2ts, 4.m2ts, and 3.m2ts, I'd like to rip just 2.m2ts and 4.m2ts, compare them, and use that comparison to select the title that I want to rip.
I can see how to make a backup of the entire disk, but that's a lot of wasted time and disk space.
Is there any way to get get the m2ts files that I want?
fryk.
Re: Ripping just selective m2ts segments?
Post by fryk. » Sat Jan 26, 2013 8:34 am
MakeMKV doesn't remux parts of titles or "m2ts". How many time does your system need for an entire BD title remux?
Smithcraft
Post by Smithcraft » Sat Jan 26, 2013 9:15 am
Or maybe cross reference with the AVS BDInfo db to see which title to rip?
SC
Post by mike admin » Mon Jan 28, 2013 8:42 am
rjbell4 wrote:However, what I'd really like to do at that point is just select the particular segments to rip. For example, if one title is segments 1.m2ts, 2.m2ts and 3.m2ts, and another is 1.m2ts, 4.m2ts, and 3.m2ts, I'd like to rip just 2.m2ts and 4.m2ts, compare them, and use that comparison to select the title that I want to rip.
This feature - splitting on any segment boundary - is planned for some time. It will ease a lot of pain when processing series disks, but should work for you too. Unfortunately I can't promise when it will be done.
rjbell4
Post by rjbell4 » Mon Jan 28, 2013 1:58 pm
Smithcraft wrote:Or maybe cross reference with the AVS BDInfo db to see which title to rip?
Yeah... if they have the info. *Someone* has to be able to figure these things out, and I like being empowered to do so myself. :-)
rjbell4
Post by rjbell4 » Mon Jan 28, 2013 2:01 pm
fryk. wrote:How many time does your system need for an entire BD title remux?
A whole lot longer than ripping just the title. I'd need to rip the entire disc, just to double back and rip just a single title. It's not impossible, but that's annoying inefficient. MakeMKV can obviously separate out the segments when ripping; all I need is a way to view and select checkboxes for the segments, instead of for the titles.
rjbell4
Post by rjbell4 » Mon Jan 28, 2013 2:03 pm
mike admin wrote:This feature - splitting on any segment boundary - is planned for some time. It will ease a lot of pain when processing series disks, but should work for you too. Unfortunately I can't promise when it will be done.
Thanks, mike. I look forward to it.
erich_7719
Post by erich_7719 » Fri Jan 26, 2024 9:33 pm
Mike,
I know this post is real old, but... Is there an update on this feature?
