I've seen a couple of CM4.0 without an active L8.speeddemon wrote: Fri Jan 26, 2024 7:31 am Are you seeing a similarity in the studios that are leaving out the 100-nit L8 Trim?
I don't know the % but I'll check my library for sure.
It is strange that it only works when L2 100nits is alone without any other trims on the C2.. It might be different on other TVs because as I mentioned, on windows Energy player, the 100nits trim is always used regardless of the other trims.
