Hi i have a Verbatim 43888 and wondered if anyone could point me in the direction of a hub in the UK, i had a couple of rips with errors that i have been told might have been power related, so drive has been working fine for the last week or so but just to be safe asking here ?
powered hub recommendations
Re: powered hub recommendations
i had the anker 60watt one and that died been using this sabrent one https://www.amazon.co.uk/SABRENT-multip ... 29&sr=8-20 for the slim drives have done upto 8 USB slim drives at once no issue
I've had good luck with Plugable USB hubs. https://plugable.com/products/usb3-hub7c
It is widely available in the USA but I have no idea if it is available in the UK.
Seen that recommended on toms hardware siteBillycar11 wrote: ↑Tue Jan 23, 2024 11:28 ami had the anker 60watt one and that died been using this sabrent one https://www.amazon.co.uk/SABRENT-multip ... 29&sr=8-20 for the slim drives have done upto 8 USB slim drives at once no issue
a quick search says not in the uk so going to go with the one Billycar11 posted, thanks anywaydcoke22 wrote: ↑Wed Jan 24, 2024 3:44 pmI've had good luck with Plugable USB hubs. https://plugable.com/products/usb3-hub7c
You might want to have a look at this thread - power supply might not be the issue.
viewtopic.php?p=147839#p147839
(I've been researching a new drive, and was leaning towards the 43888 until I saw that...)
