MakeMKV can't be used with admin privileges
Joris
#1 Post by Joris » Thu Jul 16, 2009 10:48 am
if I start MakeMKV with admin privileges, MakeMKV finds no disc drives and files can't be opened anymore (as without admin privileges).
Take a look here (both with "Log debug messages" enabled).
Without admin privileges:
With admin privileges:
My system:
- Windows XP x64 Edition SP2
- 3 optical drives (2 DVD-ROM/R-PATA, 1 BD-R/SATA)
- Panasonic DVD-RAM Driver v5.3.0.1 (MEIUDF-5.3.0.1_XP-X64_EN.exe) for UDF 2.5 support installed
After starting MakeMKV with admin privileges I have to reboot my system, because a lot of apps can't be started anymore - I suppose in this state (even after closing MakeMKV) something is wrong with HD write access.
Any help is much appreciated.
Joris
Re: MakeMKV can't be used with admin privileges
#2 Post by Joris » Sun Aug 16, 2009 6:30 pm
With MakeMKV 1.4.6 the problem still exist. :(
After starting MakeMKV I have to reset my PC, because applications can't be started any more - even if MakeMKV was closed. 'makemkvcon.exe' is still running in background and blocking anything else. :roll:
I think MakeMKV is incompatible with Panasonic DVD-RAM driver.
This driver is needed by Windows XP x64 to handle UDF 2.5 and is working flawlessly with any other application. So is there anyone, who can check this out? As I wrote above this driver (which can be used with any DVD/BD drive, available for Windows XP/Vista x86/x64) can be downloaded here. Password (german: 'Passwort') for downloading is noted on this page, too.
Thanks again.
NomadCF
#3 Post by NomadCF » Sun Aug 16, 2009 8:19 pm
Any reason why not to just use the Toshiba UDF2.5 driver. So far it works flawless on both my 32X and 64X systems with XP SP3
Joris
#4 Post by Joris » Mon Aug 17, 2009 6:20 am
Yep, I know about this driver, but I thought the Toshiba UDF 2.5 driver isn't available for 64-bit environment (Windows XP x64 Edition). If I was wrong, where can I get the 64-bit version?
NomadCF
#5 Post by NomadCF » Mon Aug 17, 2009 12:50 pm
It does but you need just need to re-adjust the inf for 64x registry entries.
Joris
#6 Post by Joris » Mon Aug 17, 2009 1:56 pm
OK, I just downloaded these Toshiba drivers:
(1) DVD-RAM Driver - Toshiba - Windows XP - 5.0.2.5 (dvdram-de-20090227140958.zip) (download link here)
(2) UDF 2.5 File System Driver for HD-DVD - Toshiba - Windows XP - 1.0.0.2 (direct download link here)
But which archive contains the right driver? And first of all, how do I need to modify the inf file to get it work on Windows XP x64 Edition?
Unfortunately Google was not my friend on this question.
Joris
#7 Post by Joris » Tue Aug 18, 2009 9:10 am
I did some additional tests and I found out that the problem mentioned above still exists even if no UDF 2.5 driver is installed at all - nevertheless I'm very interested in the Toshiba driver for 64-bit.
If I start MakeMKV with admin privileges 'makemkvcon.exe' still runs in background (after closing MakeMKV) and blocks other applications to start. Without admin privileges 'makemkvcon.exe' does the same, but it doesn't block other applications. In both cases I can't use MakeMKV, because all menu options are greyed out. Strange. :(
This problem exist since I updated to MakeMKV v1.4.5.
I would like to test some older versions, too, but I don't know where I could get them. Any ideas?
#8 Post by mike admin » Sat Aug 22, 2009 10:01 am
Just as a side note - MakeMKV does NOT require UDF driver as it has built-in UDF parser.
Kurtnoise
#9 Post by Kurtnoise » Fri Sep 25, 2009 9:37 am
get the same issue with Windows 7 rc...makemkv works fine on Vista on the same machine. So, what's wrong ?
