Hans_Meiser
#2116 Post by Hans_Meiser » Mon Jan 22, 2024 10:23 pm
I have a few small questions that I would like to ask before I flash my drive (so I don't brick it). Sorry for evetually silly questions, but my English isn't that good and I want to make sure I didn't misunderstood anything. My newly purchased LG-BH16NS40 drive has the production date November 17th, 2023, the SVC code is NS51 and the Rom version 1.05 on the Drive-Label.
1.
As far as I understood, the only difference between the LG-WH16NS40 and the LG-BH16NS40 is that the first one is a retail package (including accessories) and the other one is bulk. Therefore, both are identical!? As a result, I can follow the instructions for the LG-WH16NS40. Correct?
2.
The drive platform MUST be MT1959. According to MakeMKV, this actually applies to me. However, every now and then I read online that if you wanna make your drive "UHD friendly" you should NOT buy an LG-BH16NS40 anymore. I didn't fully understand why (because of my poor english). My drive has the SVC code NS51 and not the "desired" SVC code NS50. Is that the reason why I can't flash it UHD-Friendly and I would brick it, because of an incompatible firmware?
3.
Let's assume that in question #2 you say I can flash my drive despite the SVC code NS51 anyway. Then the "Ultimate UHD Drive flashing Guide" says that for the LG-WH16NS40 (and therefore also my LGBH16NS40?) it is recommended to directly flash the firmware WH16NS60 1.02MK. Do I understand it correctly that this is a sidegrade in order to turn the drive immediately into an UHD official drive, which also then no longer has the sleep bug?
4. Last question. If I'm allowed to flash, do I follow this (simple) procedure?:
- Download and start GUI SDF tool (By MartyMcNuts):
- Make sure the drive is empty and tray is closed.
- Select my drive from the first drop down box.
- At first make a backup with the "read"-option. After having finished:
- Select WH16NS60 1.02MK firmware in the second dropdown box
- Check the "enc?" checkbox !!!
- Press the START button to flash the selected firmware.
- Reboot!
Correct?
Ps.
Sometimes I've read something about needing the IDE-Mode on my Motherbord for flashing. Is it correct that I only need that, if something went wrong and I want to "reanimate" my bricked drive?
Thanks for all in advance ;)
#2117 Post by MartyMcNuts » Mon Jan 22, 2024 11:38 pm
Hans_Meiser wrote: Mon Jan 22, 2024 10:23 pm Hello,
1.
2.
3.
- Reboot!
Correct?
Ps.
IDE mode was for the old flashing method, so ignore any of that.
The newer versions of the SDFTool Flasher automatically apply the "enc" if needed so no need to worry about that either. Just flash the drive to WH16NS60 1.02-MK and you are good to go.
Hans_Meiser
#2118 Post by Hans_Meiser » Tue Jan 23, 2024 12:40 am
Thanks :D ... Just one last question: I've found this sentence in one thread:
"The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!"
My LG-BH16NS40 Drive SVC Code is NS51 and NOT the well known SVC Code NS50. Do I need to flash the WH16NS60 1.02-MK firmware with or without the bootloader option checked in the SDFtool Flasher?
Thanx in advance ;)
#2119 Post by Billycar11 » Tue Jan 23, 2024 2:09 am
Hans_Meiser wrote: Tue Jan 23, 2024 12:40 am Thanks :D ... Just one last question: I've found this sentence in one thread:
Thanx in advance ;)
no bootloader needed
Hans_Meiser
#2120 Post by Hans_Meiser » Tue Jan 23, 2024 3:49 pm
Thanks. Everything worked fine. I accidentally took the "DE_LG_WH16NS60_1.02_MK.bin" from the "All You Need Firmware Pack" by MartyMcNuts, but I think that firmware is exactely the same like the one in your "All you need firmware Pack" from the starting post (just with a slightly different name). I'm just a litte bit irritated, because his firmware name begins with "DE" ... and ends up with "MK" and I still do not really understand the exact difference between those two types of firmware although it is explained by him in his thread. I understood that a MK firmware is the recommended one for MakeMKV - that's enough to know for me. But because the mixed name (DE and MK) of his firmware I'm not shure whether I have the correct one. Can I identify somehow whether a DE firmware or a MK firmware has been flashed? This is my actual MakeMKV Picture:
And do I have the sleep bug with that firm now, or not ? I would say NO, correct? (Sorry, I know I'm driving you crazy :) )
#2121 Post by Billycar11 » Tue Jan 23, 2024 9:07 pm
Hans_Meiser wrote: Tue Jan 23, 2024 3:49 pm Thanks
You don't have the sleep bug
#2122 Post by MartyMcNuts » Tue Jan 23, 2024 10:05 pm
Hans_Meiser wrote: Tue Jan 23, 2024 3:49 pm Thanks. Everything worked fine. I accidentally took the "DE_LG_WH16NS60_1.02_MK.bin" from the "All You Need Firmware Pack" by MartyMcNuts, but I think that firmware is exactely the same like the one in your "All you need firmware Pack" from the starting post (just with a slightly different name). I'm just a litte bit irritated, because his firmware name begins with "DE" ... and ends up with "MK" and I still do not really understand the exact difference between those two types of firmware although it is explained by him in his thread. I understood that a MK firmware is the recommended one for MakeMKV - that's enough to know for me. But because the mixed name (DE and MK) of his firmware I'm not shure whether I have the correct one. Can I identify somehow whether a DE firmware or a MK firmware has been flashed? This is my actual MakeMKV Picture:
The "DE" simply means the firmware has been downgrade enabled. It's the same firmware as in Billy's pack.
Imperial
#2123 Post by Imperial » Wed Jan 24, 2024 6:29 am
Hi all,
I just purchased HP HLDS BU40N slim drive and gathered info(below) from MakeMVK program. I downloaded SDF Flasher and "the all ... firmware pack". I found one firmware file matching BU40N, which is "HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin". <<< Don't know if this FW is MakeMKV compatible as I don't see MK in the firmware's name.
Does anyone know, if this firmware will flash over my drive's current BW42 firmware and if I need to check "encrypted firmware in the flashing tool?
OS device name: F:
Manufacturer: hp HLDS
Product: BDRE BU40N
Revision: BW42
Serial number: -----------
Firmware date: 2117-11-29 16:55
Bus encryption flags: 1F
Highest AACS version: 16
Hardware support: Yes
Firmware support: No
Firmware version: 0.BW42P
#2124 Post by MartyMcNuts » Thu Jan 25, 2024 12:16 am
Imperial wrote: Wed Jan 24, 2024 6:29 am Hi all,
OS device name: F:
Product: BDRE BU40N
Revision: BW42
Since your current firmware is old and not encrypted, you can flash either BU40N 1.00 or BU40N 1.03-MK (which is the firmware you mentioned).
Imperial
#2125 Post by Imperial » Thu Jan 25, 2024 8:27 am
MartyMcNuts wrote: Thu Jan 25, 2024 12:16 am
OS device name: F:
Product: BDRE BU40N
Revision: BW42
Appreciate it!
1) So, if I flash the firmware, my drive's name will change and will it be recognized as HLDS(not HP)?
2) If I stay with BW42 FW, are there any known issues with it?
#2126 Post by MartyMcNuts » Thu Jan 25, 2024 10:01 pm
Imperial wrote: Thu Jan 25, 2024 8:27 am
OS device name: F:
Product: BDRE BU40N
Revision: BW42
Appreciate it!
If you stick with BW42, you won't be able to rip UHD discs and no libredrive meaning drive certificate will be revoked on new AACS versions.
As it's an old firmware, you should be able to READ a full firmware backup using SDFtool Flasher for safe keeping.
jcvb_
#2127 Post by jcvb_ » Fri Jan 26, 2024 12:58 pm
Hi guys,
I hope this is the right place to post my question.
I am looking to buy this LG BH16NS55, in hope it supports ripping of uhd blu-rays. As I don't have it yet, i can't post any information makemkv would provide. The seller sent me a picture of the drives label, but i find the information found in this thread hard to understand. Can anyone help me make sense of it?
The label states:
MODEL: BH16NS55
[chinese characters] 2016 01 25
ROM VER:1.20
MANUFACTURED: JANUARY 2016 RoHS
SVC CODE:NS55
Does this drive need to be flashed, and if so, which version would be the correct one?
#2128 Post by MartyMcNuts » Fri Jan 26, 2024 9:25 pm
jcvb_ wrote: Fri Jan 26, 2024 12:58 pm Hi guys,
The label states:
MODEL: BH16NS55
ROM VER:1.20
SVC CODE:NS55
Honestly I wouldn't buy it. Better off buying a new one and flashing it to WH16NS60 1.92-MK
turntable97
#2129 Post by turntable97 » Tue Jan 30, 2024 9:26 pm
i bought a 213EBK a few weeks ago.
Can someone provide me with a UHD firmware incl. flash tool?
Thanks !!
#2130 Post by Coopervid » Tue Jan 30, 2024 9:49 pm
turntable97 wrote: Tue Jan 30, 2024 9:26 pm Hi,
Thanks !!
You know the go to guy.
