Game of Thrones UHD Disk Issues
crowdx42
#1 Post by crowdx42 » Sat Jan 20, 2024 6:51 pm
Hi all,
so I just received my Game of Thrones UHD Box set and I am having issues ripping them. I see on the forum that others have also had issues with these disks. I am using LG WH16S60 drives flashed to the 1.02MK firmware. Is there any drive/firmware combination that works for these disks? I have been able to rip some of the disks, but season 1 disk 1 only succeeded to rip the 3rd episode, with the rest of the disk giving SCSI errors.
Any advice on this?
Thanks in advance.
Patrick
Re: Game of Thrones UHD Disk Issues
#2 Post by MartyMcNuts » Sat Jan 20, 2024 10:11 pm
Hi all,
Any advice on this?
Thanks in advance.
Patrick
Those discs are notoriously bad. Many people have had to rip what discs they could then return the set for a replacement and hopefully rip the remaining discs.
Did you try cleaning them?
If you want to try another drive, definitely go a Pioneer. For libredrive and UHD support you should get one from a seller on this forum.
crowdx42
#3 Post by crowdx42 » Sat Jan 20, 2024 11:47 pm
I have been working through the disks and getting most of the episodes. Disk One of season 1 seems to have been the worst so far, with only a single episode ripped from that disk. I am considering the pioneer drive, but they are quite expensive and I already have 3 LGs which work great for other disks so far.
I may have to do a return and get replacement disks, I am also considering downloading any of the missing episodes once I am done ripping as a Remux full disk.
Quite the headache, considering how much the set of disks cost :(
ToddUGA
#4 Post by ToddUGA » Sun Jan 21, 2024 2:32 am
Had the same issue with both an Asus drive and an LG. Decided to buy a flashed Pioneer drive and it ripped them all with no issues.
crowdx42
#5 Post by crowdx42 » Tue Jan 23, 2024 4:48 pm
As an update, I also got a Pioneer drive and it ripped the 3 disks that I had issues with, without any problems.
ToddUGA
#6 Post by ToddUGA » Tue Jan 23, 2024 4:54 pm
crowdx42 wrote:As an update, I also got a Pioneer drive and it ripped the 3 disks that I had issues with, without any problems.
Good deal. Starting to think the Pioneer drives are the way to go when you have some trouble discs.
crowdx42
#7 Post by crowdx42 » Tue Jan 23, 2024 7:34 pm
Yes, I think so. I ordered a 2nd one so that I have 2 for other multi disk rips. Price was not much more than the LG drives I already had.
initechpeter
#8 Post by initechpeter » Sun Feb 04, 2024 2:07 pm
Which Pioneer drive did you buy?
BDR-S12UHT or the BDR-S13J-X
crowdx42
#9 Post by crowdx42 » Wed Feb 07, 2024 4:47 pm
Pioneer BDR-212V
#10 Post by Coopervid » Wed Feb 07, 2024 6:39 pm
Pioneer BDR-212V
You need to say that this drive doesn't work out of the box or you are misleading people.
crowdx42
#11 Post by crowdx42 » Wed Feb 07, 2024 6:47 pm
Sorry, this is true. It did need a firmaware update which Coopervid provided. Very easy and painless upgrade. I actually bought 2 of these drives and updated both.
