Cross-flashing LG WP50NB40?
tillig
Re: Cross-flashing LG WP50NB40?
Post by tillig » Fri Dec 08, 2023 8:39 pm
The recovery process outlined there worked for my WP50NB40 as well. The flasher tool is awesome. I will say, the recovery process, while simple, is not super obvious what it's for. Maybe the name had me confused - I wasn't really "recovering" anything in the sense that I'd "lost something to recover." Is the tool on GitHub somewhere? I could throw in a PR with some tool tips or something to help.
Post by MartyMcNuts » Fri Dec 08, 2023 9:33 pm
tillig wrote: Fri Dec 08, 2023 8:39 pm The recovery process outlined there worked for my WP50NB40 as well. The flasher tool is awesome. I will say, the recovery process, while simple, is not super obvious what it's for. Maybe the name had me confused - I wasn't really "recovering" anything in the sense that I'd "lost something to recover." Is the tool on GitHub somewhere? I could throw in a PR with some tool tips or something to help.
Yes, the recovery process works for these drives but was not really what it was meant for. It's actually there to recover old drives incorrectly flashed but now has many uses.
uhd_explorer
Post by uhd_explorer » Mon Jan 22, 2024 10:19 pm
Hi @MartyMcNuts,
one question I have - having just successfully cross-flashed a new WP50NB40 to DE_LG BU40N_1.00.bin...
(which went very smoothly without a hitch btw!!!)
what exactly is the state of the drive in the "intervening" period after you do the first flash to DE_LG_WP50NB40-NB50_1.03_MK.bin
'normally' it was my understanding that an MK firmware would unlock LibreDrive and so mean that the drive could read a UHD disc, but clearly that is not the case with this unit???
viewtopic.php?f=19&t=19113
Hence, the subsequent "special" step of RECOVER-flashing to a 3rd FW is required (BU40N/BP60NB10).
Is this anything to do with why this drive (or at least the BP50NB40 variant) is listed as "UHD Officialish" in the overall guide?
viewtopic.php?f=16&t=19634
Any light (missing detail) you can shed on this would be greatly received.
Post by MartyMcNuts » Mon Jan 22, 2024 11:47 pm
uhd_explorer wrote: Mon Jan 22, 2024 10:19 pm Hi @MartyMcNuts,
The first flash to the WP50NB40 1.03-MK firmware is done to remove the firmware's encryption. This then allows the cross-flash to work.
Your assumptions are incorrect. LibreDrive does not equal UHD readability. That is not what libredrive is for. It stops your drive's certificate from being revoked when you insert a disc containing a newer AACS version than what MakeMKV can currently handle.
Some desktop drive firmware versions were capable of reading UHD discs (UHD friendly) but not slim drives variants. I don't know why so can't go further into that.
uhd_explorer
Post by uhd_explorer » Tue Jan 23, 2024 6:56 am
Many thanks Marty - I didn't know/appreciate that detail about LibreDrive. I guess a line from this page suggested otherwise in my mind?
"For BDXL compatible drives MK patch would re-enable ability to read UHD discs"
Only other remaining unknown - having removed the encryption with the first flash (allowing a subsequent flash to work), what aspect of the drive's state is the follow-on "RECOVER" flash addressing (vs just a "WRITE")?
Presumably in other scenarios (for other drives), once you've removed the encryption, a follow-on flash would be just another "WRITE" phase, rather than recover, so was just wondering about that last part!
And kind of in keeping with that theme... now that the drive is flashed with its final-target DE BU40N firmware:
  • is its CURRENTLY reported MakeMKV LibreDrive Enabled status something that was inherited purely as a result of the first-stage MK FW flash? or is that capability also a feature of the DE BU40N FW which was applied subsequently?
  • is it essentially now in a state from which ANY same-genre firmware could be applied (via regular SDFtool "WRITE") if desired (i.e. keeping within the same-genre/class bounds of slim/LG/etc)? - it currently reports as "Firmware type: Original (unpatched)", so I'm assuming it's as if it IS a BU40N drive with original/old/constraint-less FW - as if from the manufacturer
I doubt I would ever have call to further change the FW of course!
Like I said, the process, if nothing else, was very straightforward and hassle-free, and it is such a great resource to have makemkv.com to provide this utility and knowledge base.
Cheers.
Post by MartyMcNuts » Tue Jan 23, 2024 10:21 pm
uhd_explorer wrote: Tue Jan 23, 2024 6:56 am Many thanks Marty - I didn't know/appreciate that detail about LibreDrive. I guess a line from this page suggested otherwise in my mind?
Cheers.
The "RECOVER" sends different commands/information to the drive allowing the cross-flash to happen. "WRITE" does not allow the cross-flash on these slim drives.
Libredrive was enabled after the first flash. The BU40N is an official UHD drive therefore it's firmware, once flashed, enables UHD ripping.
Yes, you can now flash any BU40N firmware by using WRITE, although BU40N 1.00 is recommended. If you wanted to use another model firmware such as BP60NB10, you would use the RECOVER process.
uhd_explorer
Post by uhd_explorer » Wed Jan 24, 2024 5:42 am
Marty,
thanks again for the more-than-useful detail in your answers.
Last Q I promise :)
I see a lot of times you advocate flashing the base version (e.g. v1.00) of a device's firmware (as indeed you just did: "although BU40N 1.00 is recommended"), whereas for example a "newer" 1.03 or 1.04 MK version of the same FW might be available. Case in point: the mk-firmware-pack-20200720.zip has "HL-DT-ST-BD-RE_BU40N-1.04-NM00500-212005061142.bin" for the BU40N.
Is that (v1.00 recommendation) purely for compatibility reasons with some particular SW? Are the newer revisions not adding anything useful to the mix (i.e. are they more about rolling out lockdown constraints to limit the owner/customer, rather than improved performance)?
And alternatively, what would be the point of choosing one compatible FW family (BP60NB10) over the other (BU40N)?
Many thanks yet again.
Post by MartyMcNuts » Wed Jan 24, 2024 7:27 am
uhd_explorer wrote: Wed Jan 24, 2024 5:42 am Marty,
Last Q I promise :)
Yes, with regards to UHD discs, BU40N 1.00 is compatible with all popular ripping software, whereas MK firmware only works with MakeMKV and AnyDVD. This is also why BU40N 1.00 is recommended over any BP60NB10 firmware as there are only MK versions.
No, newer firmware does not mean better firmware. BU40N 1.03-MK + doesn't bring anything extra to the table, certainly not any improvements.
uhd_explorer
Post by uhd_explorer » Wed Jan 24, 2024 3:04 pm
One remaining point of confusion though...
If the DE_LG_BU40N_1.00.bin FW is "DE" FW (supposedly "official firmware image with a single byte changed, so this firmware can be flashed over the latest firmware"), how is it that "ending up" on that version after the (2-stages of) flashing, it can now read UHD discs?
Or is it the LibreDrive aspect from the 1st stage MK flash that, in combination with the 1.00 FW, now allows that?
Or is it that 1.00 FW just doesn't (didn't originally) restrict UHD reading/ripping anyway (and later versions did). I'm still confused over the difference between "official firmware"/"official drive" vs the ability to rip/read. If you had bought a BU40N from the manufacturer that came with BU40N 1.00 FW on it, would that have already been able to read UHD discs straight out of the box? (and newer "official" BU40N firmware "upgrades" from the manufacturer disabled that?)
I also have a couple of BU40N drives, one of which I previously flashed to HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin MK FW (from mk-firmware-pack-20191206.zip) which is working well with MakeMKV right now, having previously used the "ASUS_ODD_FW_Changer_(Modified).exe" flasher from here:
viewtopic.php?f=16&t=18933
Would I be better served (at least in terms of maximum compatibility) flashing/"downgrading" that to the DE 1.00 FW now? Is that just a "WRITE" with SDFtool from the state it's in now?
Thanks so much.
Post by MartyMcNuts » Thu Jan 25, 2024 12:14 am
uhd_explorer wrote: Wed Jan 24, 2024 3:04 pm One remaining point of confusion though...
Thanks so much.
Yes, the single byte was changed so we could downgrade to it. All BU40N drives regardless of firmware version can perform UHD disc playback. It's one of their main features! For ripping UHD discs, MakeKV uses the hashed keys which are downloaded when necessary. Libredrive also helps as the drive certificate won't get revoked.
If you only use the other BU40N with MakeMKV then you can leave it as is. If you want to use it with other software then yes, simply WRITE BU40N 1.00 to the drive.
uhd_explorer
Post by uhd_explorer » Thu Jan 25, 2024 2:20 am
Thanks again @MartyMcNuts for all the helpful responses to my many tedious questions :D
wordpuddles
Post by wordpuddles » Sun Oct 27, 2024 6:46 pm
I know this sounds redundant however I think I am one of the "slower" of users here I guess. I have a WP50NB40 and have tried to flash the drive to no avail for two days so far. It has not been bricked or anything it just following the steps as far as I can tell does absolutely nothing to downgrade the drive.
Product: BD-RE WP50NB40
Revision: 1.03
Serial number: SIM2221821859
Firmware date: 2120-05-07 09:29
Highest AACS version: 68
It retains that 1.03 version no matter what I try to do. I tried to use the SDFtool Flasher (v1.3.5). Select the drive and selected "Recover Drive" with Encrypted Firmware checked. Then I selected the firmware to write from the MK selection of firmware HL-DT-ST-BD-RE_WP50NB40-NB50-1.03-NM00800-212005070929.bin. Which from what I've read SHOULD work to flash in the MK version of the existing firmware 1.03 it came with. As I stated...it appears to do what its supposed to be doing..
Then I selected Write...with the Enc box checked as well and selected HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin. Once again..it goes from 0 to 100 percent with no apparent errors...however when I return to MakeMKV its still the original 1.03 version as I posted above. What am I doing wrong and more importantly Is anyone ever going to upload a simple current walkthrough on yt or better yet Odysee???
Post by Billycar11 » Mon Oct 28, 2024 1:07 am
wordpuddles wrote: Sun Oct 27, 2024 6:46 pm I know this sounds redundant however I think I am one of the "slower" of users here I guess. I have a WP50NB40 and have tried to flash the drive to no avail for two days so far. It has not been bricked or anything it just following the steps as far as I can tell does absolutely nothing to downgrade the drive.
Revision: 1.03
please stop trying to flash to WH16NS60 your going to kill it
see the guide below for fw flash flow chart follow bp50 same thing
or email me or marty for an auto flash kit
