Looking for 5 x libredrives
Just setting up a multi ripping pc and need 5 x drives that will work on uhd, blu ray and dvd region free, fairly new to this so need some help purchasing the correct drives asap
Re: Looking for 5 x libredrives
Uummm... Where are you located? Check with a seller in your location: viewforum.php?f=20
Thank you for the response. I’m located in England in the UK and I don’t know of any local sellers. I’ve tried contacting ASMCOM but I can’t get a response at the moment other than a generic email.
Can I just ask Will any Blu-ray internal drive rip Blu-ray movies and is it just UHD drives that I need to get the correct ones for so I can rip UHD movies?
Any blu-ray drives can rip standard blu-ray discs. Only certain models can rip UHD discs. To see what those are, check out the Ultimate UHD Guide thread.
