Re: SDFtool Flasher
#976 Post by MartyMcNuts » Sun Jan 21, 2024 11:54 pm
publisher1949 wrote: Sun Jan 21, 2024 4:06 pm I have an LG WH14NS0 that came with ver 1.05. Is there a way to restore a drive if I dumped the ROM before flashing?
Not using that dump as it only contains the important bits such as cal data.
You didn't say what model it is. Is it a WH14NS40 or WH14NS60? Anyway, if you need to return it, you can restore the drive by flashing a lower version such as 1.02-MK, 1.03-MK or 1.04-MK, depending on which is available for your drive model in the MK firmware pack then using the original LG flasher pertaining to your drive model from here: viewtopic.php?f=16&t=24443
publisher1949
Re: SDFtool Flasher
#977 Post by publisher1949 » Mon Jan 22, 2024 12:16 am
Ah my mistake, it's a WH14NS40. And yes I need to return it. I'll take a look at the link you posted. Thank you!
Re: SDFtool Flasher
#978 Post by MartyMcNuts » Mon Jan 22, 2024 12:58 am
publisher1949 wrote: Mon Jan 22, 2024 12:16 am Ah my mistake, it's a WH14NS40. And yes I need to return it. I'll take a look at the link you posted. Thank you!
Ok, so in the "old" folder of the MK firmware pack there should be a WH14NS40 1.03-MK (HL-DT-ST-BD-RE_WH14NS40-NS50-1.03-NM00600-211711211658) and a WH14NS40 1.04-MK (HL-DT-ST-BD-RE_WH14NS40-NS50-1.04-NM01201-211901041351). You should flash the drive to either one of those, then use the original LG WH14NS40 1.05 flasher from the link I provided to restore the drive to the original WH14NS40 1.05 firmware, ready for return.
natra
Re: SDFtool Flasher
#979 Post by natra » Fri Feb 02, 2024 1:41 pm
Hi, I have a quick question will my drive work for ripping 4K discs? AUSU BW-16D1H-U
hexen525
Re: SDFtool Flasher
#980 Post by hexen525 » Fri Feb 02, 2024 5:30 pm
rajeevgeorge wrote: Tue Jan 16, 2024 4:52 pm Hi
I am a newbie here, and tried to download and run the SDFtool Flasher. However, I get the following error:
"Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object."
Details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.5.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Registry
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
I apologize in advance for this long post. Any help will be welcome
I am having this same issue. Tried the ASUS tool first, caused issue #5. Downloaded the SDtool, get this error. Tried the legacy SDtool, same error. Saw your reply about the MakeMKV app installed, installed that, issue remains. Also, the box is SUPER small, doesn't show all the stuff. And as a plus, it doesn't seem to recognize my drive, no option to select it from the drop down menu.
LG WH14NS40 v1.05 installed this morning.
Win 11 Pro x64
Re: SDFtool Flasher
#981 Post by MartyMcNuts » Fri Feb 02, 2024 10:47 pm
hexen525 wrote: Fri Feb 02, 2024 5:30 pm
Details
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Accessibility
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
Win 11 Pro x64
Ensure MakeMKV is installed in the default location (C:\Program Files (x86)\MakeMKV).
Make sure there is no disc in the drive and the tray is closed.
If you are using a 4K monitor, sometimes the app may appear small. You can fix this by changing the DPI settings (see first post)
Re: SDFtool Flasher
#982 Post by MartyMcNuts » Fri Feb 02, 2024 10:48 pm
natra wrote: Fri Feb 02, 2024 1:41 pm Hi, I have a quick question will my drive work for ripping 4K discs? AUSU BW-16D1H-U
Show us your drive's MakeMKV info.
Normanator2k
Re: SDFtool Flasher
#983 Post by Normanator2k » Fri Feb 02, 2024 11:20 pm
Hello, is my drive able to get flashed for 4K rips?
OS device name: G:
Product: BD-RE BP55EB40
Revision: 1.03
Serial number: SIK01N5VB0200
Firmware date: 2121-07-08 16:06
Highest AACS version: 81
If so, which firmware should I flash it with? From what I gather so far I might have to flash several firmwares one after the other. Thank you for any advice.
hexen525
Re: SDFtool Flasher
#984 Post by hexen525 » Fri Feb 02, 2024 11:40 pm
MartyMcNuts wrote: Fri Feb 02, 2024 10:47 pm
Your advice worked like a charm! But now I have a new issue. ERROR: Command produced error code 0x82052603
Re: SDFtool Flasher
#985 Post by MartyMcNuts » Sat Feb 03, 2024 3:03 am
hexen525 wrote: Fri Feb 02, 2024 11:40 pm
What drive are you trying to flash and to what firmware?
hexen525
Re: SDFtool Flasher
#986 Post by hexen525 » Sat Feb 03, 2024 11:19 am
MartyMcNuts wrote: Sat Feb 03, 2024 3:03 am
LG WH14NS40 v1.05
Trying to load the DE_LG_WH14NS40-NS50_1.02.bin
Re: SDFtool Flasher
#987 Post by MartyMcNuts » Sun Feb 04, 2024 1:03 am
hexen525 wrote: Sat Feb 03, 2024 11:19 am
LG WH14NS40 v1.05
No, doesn't work that way. Your 1.05 is encrypted so you should flash WH16NS60 1.02-MK first, then you can flash to another firmware if you wish, although, WH16NS60 1.02-MK is recommended.
natra
Re: SDFtool Flasher
#988 Post by natra » Sun Feb 04, 2024 10:55 am
[/img]
MartyMcNuts wrote: Fri Feb 02, 2024 10:48 pm
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: RFDL020701WL
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: RS8601
Firmware version: E114/ID71
bub1551
Re: SDFtool Flasher
#989 Post by bub1551 » Tue Feb 13, 2024 4:24 pm
I've been trying to go through all the forums and trying to find someone else who's gone through this with the same drive, but can't seem to figure out any consistent experience that helps me figure out how to (or if I even can) flash my drive. The drive info is:
OS device name: E:
Product: BD-RE WH16NS40
Revision: 1.04
Firmware date: 2119-01-04 13:48
Highest AACS version: 75
When I select it in the tool, the encryption shows as the red X. Changing it to a green check and selecting the DE_LG_WH16NS60_1.02_MK firmware from the All You Need pack lets it proceed, and after progressing through the flash and saying it has completed successfully, there appears to be no change to my drive.
From what I've seen, it seems that I may need to flash it to another 1.04 version that isn't encrypted and allows downgrades, but I can't seem to find any such version in my searching.
Any guidance here would be greatly appreciated. Thanks!
Mr_Orange
Re: SDFtool Flasher
#990 Post by Mr_Orange » Tue Feb 13, 2024 9:27 pm
You don't need to change the encryption setting since SDFTool detects that automatically. If you check the first post, you will see that your firmware is not encrypted.
