I'm not sure where to ask this so I'll ask here: can the Pioneer BDR-UD04 read/write CDs? I have a CD I want to rip.
If possible which software is recommended?
Can Pioneer BDR-UD04 Read/Write CDs? [SOLVED/ANSWERED]
Apollo11
PC:
- Desktop: i7-9700K with RTX 2080 8GB w/ Windows 10 Home 64-bit.
- Laptop 1: i7-12700H with RTX 3060 w/ Debian 12 Bookworm + GNOME.
- Laptop 2: i5-7300HQ with GTX 1050 4GB w/ Windows 10 Home 64-bit.
Blu-Ray drive: Pioneer BDR-UD04 v1.14 Firmware.
Re: Can Pioneer BDR-UD04 Read/Write CDs?
Yes. Any CD ripping software.Apollo11 wrote: Sun Jan 21, 2024 11:24 pm Hi,
Apollo11
Do you have any recommendations?
PC:
CJT80
Cheers,
CJ
CJ
Nucleus
EZ CD Audio Converter:
https://www.poikosoft.com/music-converterWindows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
Apollo11
And I can get a WAV file of a specific track with it?CJT80 wrote: Mon Jan 22, 2024 12:40 pmI have used Exact Audio Copy before, was very good.
http://www.exactaudiocopy.de/
EDIT: Nevermind, I found out that it can. Will return here once my CD arrives.
PC:
morbius
dBpoweramp, excellent.
Apollo11
I successfully ripped all tracks to WAV files without any issues.
PC:
