Hi all,
so I just ordered a Pioneer BDR-212V and I am wondering which firmware works for this drive for UHD disks? I presume if it is a newer firmware when it arrives, it will not be flashable at all?
I am taking a chance on this drive and hoping it is flashable, otherwise I will probably end up buy a pre-flashed drive from Billy.
Patrick
Ordered a Pioneer BDR-212V
Re: Ordered a Pioneer BDR-212V
As an update, I received my BDR-212V and flashed it and everything went smoothly. The drive is currently reading my Game of Thrones disks that my LG drives refused to rip.
Hi all!
New user here, reading and learning. I want to buy the same drive. Hopefully on Amazon I will get one that is flashable.
Can you please share with me how you did it, and which firmware you loaded (which was the original question).
Gonchisky
Gonchisky
I am curious as well!
lewisvillebryan
@Coopervid
I have a Pioneer BDR-212V with v1.02 firmware. Is there a firmware to flash this drive? Do you need any other info?
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Revision: 1.02
lewisvillebryan wrote: ↑Sun May 12, 2024 11:17 pm@Coopervid
Revision: 1.02
i think Coopervid is done for now not sure if thats towards person though
pm him and find out yes you have to earn pm...
lewisvillebryan
Thank you Billycar11, ill try to pm him.
We need your country of residence.
PM sent. If not read within 3 days PM will be deleted.
