Hi all,
so I just received my Game of Thrones UHD Box set and I am having issues ripping them. I see on the forum that others have also had issues with these disks. I am using LG WH16S60 drives flashed to the 1.02MK firmware. Is there any drive/firmware combination that works for these disks? I have been able to rip some of the disks, but season 1 disk 1 only succeeded to rip the 3rd episode, with the rest of the disk giving SCSI errors.
Any advice on this?
Thanks in advance.
Patrick
Game of Thrones UHD Disk Issues
Re: Game of Thrones UHD Disk Issues
Those discs are notoriously bad. Many people have had to rip what discs they could then return the set for a replacement and hopefully rip the remaining discs.crowdx42 wrote: Sat Jan 20, 2024 6:51 pm Hi all,
Any advice on this?
Thanks in advance.
Patrick
Did you try cleaning them?
If you want to try another drive, definitely go a Pioneer. For libredrive and UHD support you should get one from a seller on this forum.
I have been working through the disks and getting most of the episodes. Disk One of season 1 seems to have been the worst so far, with only a single episode ripped from that disk. I am considering the pioneer drive, but they are quite expensive and I already have 3 LGs which work great for other disks so far.
I may have to do a return and get replacement disks, I am also considering downloading any of the missing episodes once I am done ripping as a Remux full disk.
Quite the headache, considering how much the set of disks cost
Had the same issue with both an Asus drive and an LG. Decided to buy a flashed Pioneer drive and it ripped them all with no issues.
As an update, I also got a Pioneer drive and it ripped the 3 disks that I had issues with, without any problems.
Good deal. Starting to think the Pioneer drives are the way to go when you have some trouble discs.crowdx42 wrote:As an update, I also got a Pioneer drive and it ripped the 3 disks that I had issues with, without any problems.
Yes, I think so. I ordered a 2nd one so that I have 2 for other multi disk rips. Price was not much more than the LG drives I already had.
initechpeter
Which Pioneer drive did you buy?
BDR-S12UHT or the BDR-S13J-X
Pioneer BDR-212V
You need to say that this drive doesn't work out of the box or you are misleading people.
Sorry, this is true. It did need a firmaware update which Coopervid provided. Very easy and painless upgrade. I actually bought 2 of these drives and updated both.
