aboulfad
Post by aboulfad » Fri Jan 19, 2024 11:50 pm
RESET_9999 wrote: Fri Jan 19, 2024 9:21 pm new test file like the eagle beak sample but this time, the L2 trims are a positive lift..
Sorry what's supposed to happen (I forget a lot :-D). Tried it on Oppo (TV-Led)/E7 & maybe noticed a change in brightness in the first transition.
Post by RESET_9999 » Sat Jan 20, 2024 12:20 am
aboulfad wrote: Fri Jan 19, 2024 11:50 pm
The L2 offset metadata with positive lift (over 2048) has no effect on TV-LED HDMI devices which makes the image darker than the TV's internal player. I just checked on my C2 and its quite noticeable.
I made another test file with even lower nits and you still can see the effect is missing on HDMI devices. It's not as obvious as the true detective sample but look closely in the background, the vegetation..
P8: https://drive.google.com/file/d/1heOJEH ... drive_link
P5:https://drive.google.com/file/d/1UfXlDb ... sp=sharing
PS The files are not generated metadata, they are real scenes, original L2 trims and L1.
aboulfad
Post by aboulfad » Sat Jan 20, 2024 1:31 am
Post by RESET_9999 » Sat Jan 20, 2024 2:40 am
I dont know, click on the links you quoted maybe? :) I did 3 new samples in total now.
One more test file, The L2 trim offset bug is a lot more obvious in this one because I took the latest Mission Impossible which has a huge positive lift well over 0.025 so it should be also a good test for raised black bars on device that ignores L5.
P5 https://drive.google.com/file/d/1HcrR1q ... drive_link
P8 https://drive.google.com/file/d/1ndR6_S ... sp=sharing
01/19/2024/21:38:23.977000000 Metadata: WARNING List of WARNINGS:
WARNING: Positive Level2 lift value at shot: UniqueID = 878da093-c182-467d-9789-a3820925e8de @[72-143]
WARNING: Positive Level2 lift value at shot: UniqueID = 7cb187ca-8223-452c-9c1b-a5ea6630f57b @[144-215]
WARNING: Positive Level2 lift value at shot: UniqueID = 553c4b3c-7089-4ade-8c9b-946ebb3155e8 @[216-287]
WARNING: Positive Level2 lift value at shot: UniqueID = 7151a44a-04dc-4da7-ac40-b590300040a4 @[360-431]
WARNING: Positive Level2 lift value at shot: UniqueID = 4916d773-7b0b-47be-9901-1e6fa8a2eac0 @[432-503]
WARNING: Positive Level2 lift value at shot: UniqueID = bb1e45bd-98c9-4821-ac25-c960724fb227 @[504-575]
WARNING: Positive Level2 lift value at shot: UniqueID = 393b8fb1-ee7b-436e-8ec5-40bf25e2e76d @[576-647]
WARNING: Positive Level2 lift value at shot: UniqueID = 0417d25c-77b0-4705-89bb-d05f1f4fdb31 @[648-719]
WARNING: Positive Level2 lift value at shot: UniqueID = 86c6e0a8-bf93-488b-b795-a79fb5ecf13c @[720-791]
WARNING: Positive Level2 lift value at shot: UniqueID = 694710e5-e4a9-45b3-bd7b-8b7f2de37e53 @[792-863]
01/19/2024/21:38:23.978000000 metafier: No issues found in the Metadata
aboulfad
Post by aboulfad » Sat Jan 20, 2024 11:08 am
RESET_9999 wrote: Sat Jan 20, 2024 2:40 am I dont know, click on the links you quoted maybe? :) I did 3 new samples in total now.
Weird, I did click on the new links & it downloaded yesterday the ‘true detective’ samples, Maybe some weird browser caching issue. Now I see it’s ’role play’.
I am having trouble in general focusing on subtle differences when switching from Oppo to E7, as choosing media on E7 & all the clicking & DV negotiating/switching takes around 10s. What’s your methodology or do you take photos/videos to compare after ? Some differences are very evident and easy to spot/recall (eagle beak, multi pattern, …) but some others aren’t.
Post by RESET_9999 » Sat Jan 20, 2024 1:58 pm
it's not complicated to see. positive Trim offset just doesnt work on HDMI device TV-LED.
Also switching from plex/kodi to bluray input takes less than 2 sec on my setup.
aboulfad wrote: Sat Jan 20, 2024 11:08 am I am having trouble in general focusing on subtle differences when switching from Oppo to E7, as choosing media on E7 & all the clicking & DV negotiating/switching takes around 10s. What’s your methodology or do you take photos/videos to compare after ? Some differences are very evident and easy to spot/recall (eagle beak, multi pattern, …) but some others aren’t.
aboulfad
Post by aboulfad » Sat Jan 20, 2024 4:27 pm
Yeah sorry, my TV is old & it's super clunky to switch. Even w auto-play/resume disabled, when I switch back to it it start playing the video,...
Anyways, I can't see any changes (darker) or I don't know what to see or my TV internal player doesn't show those differences (focusing on "true detective"). I'd say both Oppo & TV internal player look very close. If I ever figure out how to take perfect photos, I can share.
Post by RESET_9999 » Sat Jan 20, 2024 5:31 pm
no photo is needed, you should see a visible change for L1 + L2 (no offset) on your TV internal player but not on your Oppo or ATV in tv-led. Same story if you take any of the patterns quietvoid and I did but these new test files are with real content.
True Detective sample: Offset response is quite obvious on the internal TV player
Role Play: almost unnoticeable, the vegetation in the background is brighter with L2 offset on the internal TV player
Mi death reckoning: you cannot miss this one, there is a huge positive lift.
Batman (just added in my GD): very slight change with trims offset on TV internal player only
JCLG8
Post by JCLG8 » Sat Jan 20, 2024 9:06 pm
Does LLVD have crushed and/or raised blacks?
Post by RESET_9999 » Sat Jan 20, 2024 9:09 pm
if the EDID min target is not 0nits, yes, LLDV has raised black on all the devices I tested.
Crushed, I don't know
JCLG8
Post by JCLG8 » Sat Jan 20, 2024 9:26 pm
Is the EDID min target based on the video file or the TV?
Post by RESET_9999 » Sat Jan 20, 2024 9:27 pm
TV
JCLG8
Post by JCLG8 » Sat Jan 20, 2024 9:31 pm
Where can I see my TV's EDID?
Post by RESET_9999 » Sat Jan 20, 2024 9:40 pm
With hdmi devices like HDfury vertex or raspberry pi + Pgen.
There might be other ways I'm not aware of but I know that there is some cheap HDMI splitter that can let you upload any edid(I have one for any brightness).
which TV? All the Sony LLDV EDID I've seen had the min pq target set to 0
JCLG8
Post by JCLG8 » Sat Jan 20, 2024 9:44 pm
It's a Panasonic GX800, its a bit old, from 2019.
