Asus BW-16D1HT fails after first title
ExplodingLemur
Post by ExplodingLemur » Sat Jan 20, 2024 8:56 pm
I have an Asus BW-16D1HT in an NST-536S3 NexStar DX enclosure. I am able to extract the first title from a disc just fine. After that however the drive seems to disappear and subsequent titles fail to read. The OS does not see the drive and it's not until I fully shut down my computer, power off the drive, and then power everything back up again that it comes back. I am then able to extract the second title from the disc but it fails subsequent titles in exactly the same way.
Drive info:
OS device name: I:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KL5N7ED2419
Bus encryption flags: 1F
Highest AACS version: 75
Firmware version: 3.10
MakeMKV output:
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
File 00007.mpls was added as title #0
File 00003.mpls was added as title #1
File 00002.mpls was added as title #2
File 00001.mpls was added as title #3
File 00008.mpls was added as title #4
File 00004.mpls was added as title #5
File 00006.mpls was added as title #6
Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 5 titles into directory F:/
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '1702625280'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom0' at offset '1702625280'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '1702625280'
Failed to save title 2 to file F://Babylon 5 - Season 1_t02.mkv
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '0'
Failed to save title 3 to file F://Babylon 5 - Season 1_t03.mkv
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00106.m2ts' at offset '0'
Failed to save title 4 to file F://Babylon 5 - Season 1_t04.mkv
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00104.m2ts' at offset '0'
Failed to save title 5 to file F://Babylon 5 - Season 1_t05.mkv
1 titles saved, 4 failed
Re: Asus BW-16D1HT fails after first title
Post by Billycar11 » Sat Jan 20, 2024 10:02 pm
That's kinda normal with dirty discs in an LG or Asus they just decide to disappear.
You can try cleaning the discs and laser but those drive are just frustrating junk
I recommend a pioneer with old fw I have them.
ExplodingLemur
Post by ExplodingLemur » Sun Jan 21, 2024 4:46 pm
The disc just came out of the package and is clean, and the drive is also new. There are no issues when extracting each individual title. It just disappears after finishing whatever title it started with.
rifth427
Post by rifth427 » Wed Jan 24, 2024 10:19 pm
Did you ever solve this problem? It sounds like a low power problem to the USB or possibly a usb 2.0 cable instead of 3.0 being used.
ExplodingLemur
Post by ExplodingLemur » Thu Jan 25, 2024 1:36 am
I have not. The enclosure has its own power supply and I am using a USB3 cable. Like I said it will complete an entire title just fine, but the drive disappears after completing that title. I would expect power or USB problems to present while reading.
