Game of Thrones UHD Disk Issues
crowdx42
Post by crowdx42 »
Hi all,
so I just received my Game of Thrones UHD Box set and I am having issues ripping them. I see on the forum that others have also had issues with these disks. I am using LG WH16S60 drives flashed to the 1.02MK firmware. Is there any drive/firmware combination that works for these disks? I have been able to rip some of the disks, but season 1 disk 1 only succeeded to rip the 3rd episode, with the rest of the disk giving SCSI errors.
Any advice on this?
Thanks in advance.
Patrick
Re: Game of Thrones UHD Disk Issues
crowdx42 wrote: Sat Jan 20, 2024 6:51 pm Hi all,
Any advice on this?
Thanks in advance.
Patrick
Those discs are notoriously bad. Many people have had to rip what discs they could then return the set for a replacement and hopefully rip the remaining discs.
Did you try cleaning them?
If you want to try another drive, definitely go a Pioneer. For libredrive and UHD support you should get one from a seller on this forum.
crowdx42
Post by crowdx42 »
I have been working through the disks and getting most of the episodes. Disk One of season 1 seems to have been the worst so far, with only a single episode ripped from that disk. I am considering the pioneer drive, but they are quite expensive and I already have 3 LGs which work great for other disks so far.
I may have to do a return and get replacement disks, I am also considering downloading any of the missing episodes once I am done ripping as a Remux full disk.
Quite the headache, considering how much the set of disks cost :(
ToddUGA
Post by ToddUGA »
Had the same issue with both an Asus drive and an LG. Decided to buy a flashed Pioneer drive and it ripped them all with no issues.
crowdx42
Post by crowdx42 »
As an update, I also got a Pioneer drive and it ripped the 3 disks that I had issues with, without any problems.
ToddUGA
Post by ToddUGA »
crowdx42 wrote:As an update, I also got a Pioneer drive and it ripped the 3 disks that I had issues with, without any problems.
Good deal. Starting to think the Pioneer drives are the way to go when you have some trouble discs.
crowdx42
Post by crowdx42 »
Yes, I think so. I ordered a 2nd one so that I have 2 for other multi disk rips. Price was not much more than the LG drives I already had.
initechpeter
Post by initechpeter »
Which Pioneer drive did you buy?
BDR-S12UHT or the BDR-S13J-X
crowdx42
Post by crowdx42 »
Pioneer BDR-212V
crowdx42 wrote: Wed Feb 07, 2024 4:47 pm Pioneer BDR-212V
You need to say that this drive doesn't work out of the box or you are misleading people.
crowdx42
Post by crowdx42 »
Sorry, this is true. It did need a firmaware update which Coopervid provided. Very easy and painless upgrade. I actually bought 2 of these drives and updated both.
