(Partially) unable to extract 7.1 DTS lossless
mac-media
Post by mac-media »
thank you for this software which works fine except one issue, which causes me not only to read in this forum but also to share my experiences.
I do have an audio problem with MakeMKV and BluRay Discs. May be the problem is related to this topic:
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3874
When I backup a BD I am not able to safe the 7.1 HD-Audio track of the German language.
I do backup the HD-lossless the DTS-Core and the extra DTS tracks in German and English
As result my ..mkv File has 6 audio tracks. When I compare the audio information, 5 tracks show identical information in the track info of the BluRay and the track info of the .mkv.
Otherwise the German HD-audio looks totally different. Since the English HD is OK I think I haven't made any mistakes.
Here is an abstract of the info’s I've gathered:
BD Info in MAKEMKV:    vs.    .MKV Info in VLC
Spurinformationen              Spurinformationen
Typ: Audio                     Typ: Audio
Name: HRA XXCH                 Name: HRA XXCH
Sprache:German                 Sprache:German
Codec: DTS-HD                  Codec: DTS Audio (dts)
Kan?le:8                       Kan?le 3F2R LFE
Abtastrate: 48000 kHz          Bitrate: 1536 Bit/s
Bits pro Sample: 24            Bits pro Sample: 24
Sprache:English                  Sprache:English
Codec: DTS-HD                    Codec: DTS-HD
Kan?le:8                         Kan?le:8
Abtastrate: 48000 kHz            Abtastrate: 48000 kHz
I've tested it with following BluRay on OSX and Windows XP. In MakeMKV 1.6.8 and 1.6.12. Always with identical results:
Fight Club
Leon
Bank Job
I haven't tested it with an 5.1 DTS-HD Audio BluRay. The BD-Player is an external Panasonic BD-UJ 240.
Any advices?
Thank you in advance mac-media
Re: (Partially) unable to extract 7.1 DTS lossless
Post by mike admin »
DTS-HD is an umbrella name for 3 different codecs: XXCH (lossy encoding for more than 5 channels), LBR (lossy encoding of low-bitrate audio) and XLL ( master audio, lossless encode for any audio). In your case you have DTS-HD XXCH and not the common DTS-HD XLL also known as DTS-HD MA. Vlc can only see the core audio, hence 5.1 channels.
Presently, there is no open-source decoder capable to decode any form of DTS-HD.
mac-media
Post by mac-media »
Hello Mike,
thank you for your answer.
Meanwhile I’ve used “mediainfo”. I found out, that the HD-Streams are still there.
Now, your answer is giving me an illustrative explanation.
Greetings, mac-media
