Volume key is unknown disc failed to open.
Sent the dump file named: MKB20_v77_Oldboy_33BE.tgz to svq@makemkv.com.
Neon Oldboy 4K UHD
ThrowAway227
Re: Neon Oldboy 4K UHD
Been trying every so often with no success. Been getting this error though so I'm not so sure I would know if its been fixed:
DEBUG: Code 4279336995 at 5Q45#y{(<sIV_|':121262877
DEBUG: Code 0 at ]K}<{g 5\^[xCzt/:29400163
In the past I haven't had to flush DNS or anything else with other problem UHD discs. I just waited till I saw a post that it was fixed and it would work without issue. Any insight would be appreciated.
If you're getting that message, then MakeMKV is not downloading updated keys. You definitely need to fix that.
See this thread: https://forum.makemkv.com/forum/viewtopic.php?f=1&t=20851&start=15
