Neon Oldboy 4K UHD
ThrowAway227
Neon Oldboy 4K UHD
Post by ThrowAway227 »
Volume key is unknown disc failed to open.
Sent the dump file named: MKB20_v77_Oldboy_33BE.tgz to svq@makemkv.com.
ThrowAway227
Re: Neon Oldboy 4K UHD
Been trying every so often with no success. Been getting this error though so I'm not so sure I would know if its been fixed:
DEBUG: Code 4279336995 at 5Q45#y{(<sIV_|':121262877
DEBUG: Code 0 at ]K}<{g 5\^[xCzt/:29400163
In the past I haven't had to flush DNS or anything else with other problem UHD discs. I just waited till I saw a post that it was fixed and it would work without issue. Any insight would be appreciated.
ThrowAway227 wrote: Thu Jan 18, 2024 5:30 am Automatic HK downloading is disabled or failed.
If you're getting that message, then MakeMKV is not downloading updated keys. You definitely need to fix that.
See this thread: https://forum.makemkv.com/forum/viewtopic.php?f=1&t=20851&start=15
