Problems with Dracula 1931
outland
Post by outland »
Latest MakeMKV can't decrypt "DRACULAE1931_UPK1."
How do I submit a file? I mean how to I send it.
outland
Re: Problems with Dracula 1931
Post by outland »
Found it here:
viewtopic.php?t=16959
outland
Post by outland »
outland
Post by outland »
So, what is the norm when you submit a dump. Do you get a reply or keep trying the disc?
htpc_rookie
Post by htpc_rookie »
Keep trying the disc. It will not be immediate.
outland
Post by outland »
Still not working. Is that normal or perhaps they did not get the mail?
outland wrote: Sat Mar 09, 2024 12:28 pm Still not working. Is that normal or perhaps they did not get the mail?
I usually only takes a couple of weeks. I'd submit your dump file again.
Are you getting any error messages in your log about downloading new hashed keys?
