aboulfad wrote: Mon Jan 15, 2024 5:36 pm Oh that hurt my eyes, you should put a "seizure" warning :mrgreen: & that joker shot eery ! So I can see at the start "This device can decode..." & I think the whole test pattern looks similar on both E7 & Oppo. Though there's too much going on & idk the purpose of those flashes. I didn't follow much few years ago about the FEL decoding...
haha, yeah the flashes are the RPU mapping data. I tried to remove them but then the pattern no longer worked. Thanks for testing.
PS: btw @speeddemon confirmed the DV cal is similar on C2, so what did your calibrator calibrate, maybe he transferred the file over network to your TV without you noticing ?
He's someone I know ( well a friend of a friend) and he didn't give me any file and he only showed me the calman results graph on his laptop and told me to call him if I noticed anything wrong after firmware updates.
That is also why I never really touch with my C2, I'm scared to mess up the calibration.
The fact that chroma weight doesn't work with the default config on your E7 is very strange though, I hope you can find your original data so we can compare with your custom config.
aboulfad
Post by aboulfad »
RESET_9999 wrote: Mon Jan 15, 2024 5:45 pm ... The fact that chroma weight doesn't work with the default config on your E7 is very strange though, I hope you can find your original data so we can compare with your custom config.
The DV cal profile is supposed to persist after firmware updates, it must be stored in some special area (still hunting for it). He must have transferred it over the network as @speeddemon described. You can't mess anything bcoz you don't have it :)
I have found a bunch of DV profile data lying around in the firmware, but it requires a DV calibrator to understand the entries. I paste above the one I re-used from sonoftumble@avsforum.
PS: I also tested the Multi.Pattern with & without a custom DV profile, there's few sections on that pattern that fail without the custom DV profile: most notable is tracking & color space conversion from a quick glance.
afarvvik
Post by afarvvik »
RESET_9999 wrote: Sat Jan 06, 2024 1:31 pm
speeddemon wrote: Sat Jan 06, 2024 6:41 am @RESET_9999 have you been able to test the color saturation/accuracy on the 23AFTVS4KM?
For DV MKV playback, I've been using my C2 internal player lately. It seems stable and it works very well, at least for the 3 movies I watched so far.
You have to sideload Kodi in developer mode but it's not too complicated to do and its pretty nice to finally have DV MKV support on LG TVs.
https://kodi.wiki/view/HOW-TO:Install_Kodi_for_webOS
hi @RESET_9999
have you also installed this kodi on your C8? I have a c8 and was considering trying this. the kodi wiki says it supports webos 4+ (C8 is 4.4.2) but somewhere I read that it works properly only with webos 5+?
if you have, would love to know how it works with DV MKV files? what are the negatives etc. I read earlier in this thread you said there were major issues if the mkv had HD audio but what about with regular DD/DTS (5.1, 7.1, atmos)?
also was wondering if there was any additional stress on the TV (for eg higher CPU usage or something like that) compared to using plex/emby as I would not want it to affect the tv.
TIA
I dont have the C8 anymore so I dont know.
Lossless audio is still a problem on my C2:
1- 5.1 dts or truehd play as 2 channels pcm + DV which is better than on plex where it falls back to HDR10. (C8 should be fine with DTS though)
2- 7.1 dts or truehd completely break the app for me and I have to restart the TV.
3- plex audio selection is inverted in kodi.
4- ddp 1536kbps stutter
solution:
encode DDP at 1024kbps and configure kodi to always select the track with the ''default'' flag. This has been 100% stable on my end (video + audio).
CPU usage seems fine but the memory usage is very high (80% +). I'm not sure if it's normal or fine. I never checked the ram usage using plex.
sw5163
Post by sw5163 »
RESET_9999 wrote: Mon Jan 15, 2024 8:49 pm Lossless audio is still a problem on my C2:
No TV can passthrough TrueHD/DTS-HD from internal app player to receiver/soundbar right?
dom61
Post by dom61 »
Interesting article I found.
"With HDR, the important thing is not brightness."
https://www.dday.it/redazione/48155/i-c ... luminosita
Video demonstrating peak brightness measurement in amateur filming.
https://www.youtube.com/watch?v=PRSm2v7bfVo
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
afarvvik
Post by afarvvik »
solution:
thanks for the reply.. so it seems it may not be a great alternative to emby as you still have to reencode files? what about if the files already have DDP with bitrate lower than 1024kbps? are they ok or does it have to be exactly that number?
it would be great if you ever got the chance to compare the CPU/RAM usage of kodi vs the other players.
would you know how they are able to process DV MKV files when it is seemingly incompatible with the TV OS?
no, any bitrate under 1024
I don't know and it doesn't really matter as long as its not fake.
some can
azreil24
Post by azreil24 »
Would transferring the EL from a release to another be possible and if so would it be feasible?
possible, yes i guess but i would not do that.
azreil24
Post by azreil24 »
Asking for the same movie, but different encoding. One has HDR10 only and another has DV, EL+RPU, just that the RPU on it is not proper and though if I'm going to replace the RPU with the one from you, maybe I could have the EL 'transplanted' to another version which also has a better encode of the transfer.
Also, have you ever tested your Z9X for SDR output when you had it? I could swear that even in SDR this thing is not as good as the internal player. I got a Z9X Pro and this thing is buggy as hell, worse than nVidia drivers. The Z9X looks as if transcoded, as it looks the same when the same content is transcoded through Plex, although on the Z9X I'm playing it directly through the built-in player which technically is direct play.
Well, I think the BL is encoded a specific way when it's meant for FEL DV so I guess it would work but it might cause issues.
Zidoo: SDR and HDR10 were fine when I tested it.
azreil24
Post by azreil24 »
I will try it, but first will have to see the RPU syncing steps, as I'm not to clear on that, as the two editions do not perfectly line-up, there is a few hundred milliseconds difference between the 'donor' and the 'patient' :D
I show how to resync the rpu in my P8 hybrid tutorial video on YouTube.
You can't really resync FEL though.
https://www.youtube.com/watch?v=hVWZpat34oc
afarvvik
Post by afarvvik »
@RESET_9999
is there a workflow or script which can simply convert a mkv file to mp4 without encoding or demuxing & remuxing etc? I currently use tsmuxer to do that as it converts mkv to m2ts on the fly so I only need about 110% of the original file as free space, whereas if I were to demux it, then convert/encode it and then remux it I would need 3x the free space.
