The Creator UK
htpc_rookie
The Creator UK
Post by htpc_rookie » Mon Jan 15, 2024 1:26 pm
Dump file submitted
MKB20_v77_THE_CREATOR_96AE
Simbo
Re: The Creator UK
Post by Simbo » Mon Jan 15, 2024 2:22 pm
Ditto
htpc_rookie
Re: The Creator UK
Post by htpc_rookie » Tue Jan 16, 2024 11:14 am
Wow, that was quick.
I’m ripping it now, fingers crossed.
Simbo
Re: The Creator UK
Post by Simbo » Tue Jan 16, 2024 1:59 pm
Excellent :D
zastarasta
Re: The Creator UK
Post by zastarasta » Mon Mar 11, 2024 6:30 pm
Dump file submitted
Ditto
Re: The Creator UK
Post by dcoke22 » Tue Mar 12, 2024 3:56 am
Dump file submitted
Ditto
I don't understand your comment. The OP indicated a hashed key was available and the disc was decrypting. If you have the same hashed key as the OP (if your dump file is the exact same name), then a key should be available.
zastarasta
Re: The Creator UK
Post by zastarasta » Thu Mar 14, 2024 6:31 am
I send the Dump from The Creator
