A general question about discs that need new decryption keys:
Do you need to update the MakeMKV application itself to handle such discs, once someone figures out the needed decryption, or does MakeMKV "phone home" to get the new key without having to be updated?
Barbie 4K
Re: Barbie 4K
From the UHD FAQ (recommended read):RasterEyes wrote: Wed Oct 18, 2023 6:51 pm A general question about discs that need new decryption keys:
How does MakeMKV work with UHDs?
MakeMKV uses Hashed Keys. Originally supplied via a download, MakeMKV now updates automatically. Go to View / Preferences / General and ensure that "Enable Internet access" is checked.
arules99
Re: Barbie 4K
Attaching dump of file MKB20_v77_Barbie_F028.tgz
Gertting "cannot decrypt" error.
Amazon 4k UHD disk.
Pleae advise as to when a new patch is available.
Amazon 4k UHD disk.
Re: Barbie 4K
Don't attach it here. You should email it to svq@makemkv.com. There won't be any notifications about it, just retry your disc every few days.arules99 wrote: Wed Oct 18, 2023 11:47 pm Attaching dump of file MKB20_v77_Barbie_F028.tgz
Amazon 4k UHD disk.
haec0007
Re: Barbie 4K
I have submitted the dump for MKB20_v77_BARBIE_5BD0.tgz
Sunoo
Re: Barbie 4K
MKB20_v77_Barbie_F028 is now working.
chrispgriffin
Re: Barbie 4K
Can confirm, as well!
Coopers
Re: Barbie 4K
New error? MKB20_v77_Barbie_D876. Just sendt inn.
SvaLLe
Re: Barbie 4K
I have a new one as well, which has been sent in by mail
MKB20_v77_Barbie_D876.tgz
SvaLLe
Re: Barbie 4K
So I can confirm that MKB20_v77_Barbie_D876.tgz also works, thanks a lot guys
arcturus_
Re: Barbie 4K
I am also having an issue with MKB20_v77_Barbie_5BD50 not having a known volume key, so I emailed the dump file. Anyone having success with this particular disc?
EDIT: Something on my network was blocking the automatic SDF downloading. I installed a VPN and had no further trouble ripping this disk.
creon
Re: Barbie 4K
Got a volume key unknown error on the disc I just got.
Submitted MKB20_v77_Barbie_6D16.tgz yesterday.
saxman
Re: Barbie 4K
I also got a volume key unknown error on two discs I got (I re-ordered a second to make sure the disc wasn't just faulty). I submitted MKB20_v77_Barbie_4EAA for the second disc I received, which had the same hash as the first. Must be a new disc specific key in my area.
creon
Re: Barbie 4K
MKB20_v77_Barbie_6D16.tgz now works. Thanks!
