aboulfad wrote: ↑Mon Jan 15, 2024 5:36 pm
Oh that hurt my eyes, you should put a "seizure" warning
& that joker shot eery ! So I can see at the start "This device can decode..." & I think the whole test pattern looks similar on both E7 & Oppo. Though there's too much going on & idk the purpose of those flashes. I didn't follow much few years ago about the FEL decoding...
haha, yeah the flashes are the RPU mapping data. I tried to remove them but then the pattern no longer worked. Thanks for testing.
PS: btw @speeddemon confirmed the DV cal is similar on C2, so what did your calibrator calibrate, maybe he transferred the file over network to your TV without you noticing ?
He's someone I know ( well a friend of a friend) and he didn't give me any file and he only showed me the calman results graph on his laptop and told me to call him if I noticed anything wrong after firmware updates.
That is also why I never really touch with my C2, I'm scared to mess up the calibration.
The fact that chroma weight doesn't work with the default config on your E7 is very strange though, I hope you can find your original data so we can compare with your custom config.
