aboulfad
#9526 Post by aboulfad » Sun Jan 14, 2024 11:04 pm
@RESET_9999, this is odd. I decided to factory restore my "Cinema" mode, also restore to factory the DOVI calibration profile. I did this bcoz I was curious how does the custom DV Profile & its white balance settings impact image quality.
Using default "Cinema" pic mode, I played on my Oppo the eagle beak test & there was NO more change between the "original" & "no-trim-chroma-weight" shots. What does calibration have to do with trim-chroma-weight handling ? (27s in MOVIE - ip13 DV)
#9527 Post by RESET_9999 » Mon Jan 15, 2024 4:29 am
strange, I dont know.
aboulfad
#9528 Post by aboulfad » Mon Jan 15, 2024 11:17 am
Any other test pattern you can recommend to test Player-led vs LLDV? (not doubting my TV isn’t capable, just wanting to understand)
#9529 Post by RESET_9999 » Mon Jan 15, 2024 12:05 pm
theres a test file on the SM disc but I can't spot the m2ts.
PS: I did a P5 version of the eagle beak test file: https://drive.google.com/file/d/1F0JPmi ... sp=sharing
aboulfad
#9530 Post by aboulfad » Mon Jan 15, 2024 12:29 pm
I think you've made the P5 eagle so I can play it on my E7 (USB), thank you ! Results are identical between Oppo & E7 usb DV: NO change between 'original' & 'no-trim-chroma-weight' using same file with default 'Cinema' pic mode.
OK I re-applied this custom DV cal profile (Tmax = 759) & boom, there is the clear change between 'original' & 'no-trim-chroma-weight' shots as in Vincent's video & my previously shared screenshots.
idk what that means & if it means anything :|
#9531 Post by RESET_9999 » Mon Jan 15, 2024 1:12 pm
On Windows Energy Player(400nits edid), the eagle chroma weight also doesn't have a response but it looks like it doesn't need to, the beak already looks bright yellow. But if I use another test file, it reacts to CW.
other CW test files:
https://drive.google.com/file/d/1XLtTsj ... sp=sharing
https://drive.google.com/file/d/18PLzRP ... sp=sharing
On the C2, no reaction at all on any of the test files and the eagle beak looks darker green like in HDR10, not bright yellow as it should.
azreil24
#9532 Post by azreil24 » Mon Jan 15, 2024 1:36 pm
Which part of the test shows a darker green beak? I haven't noticed any green tint on my C2, which is also calibrated.
aboulfad
#9533 Post by aboulfad » Mon Jan 15, 2024 1:45 pm
In Vincent's video, he mentions green but I also don't see a green tint or color. Though @RESET_9999 mentioned it isn't the color that is important, rather some visible change between the 'original' & 'no-trim-chroma-weight' shots. (see correction in this POST).
#9534 Post by RESET_9999 » Mon Jan 15, 2024 1:59 pm
DV chroma weight makes the eagle beak bright yellow instead of greenish looking in HDR10. You can see it in @Vincent video and @aboulfad pictures.
On the C2, CW doesn't work and the beak looks more like HDR10(darker yellow greenish)
#9535 Post by RESET_9999 » Mon Jan 15, 2024 2:05 pm
No, I mentioned that it doesn't matter how it looks in the inaccurate cinema home mode.
The beak is supposed to look bright yellow.
aboulfad
#9536 Post by aboulfad » Mon Jan 15, 2024 2:06 pm
Yeah, in this collection: LG DV Picmode Oppo, you see the green, but that was ONLY when I used inaccurate Cinema Home. When I used Cinema (w LG DV cal profile + 2/20 points settings), both shots looked yellow to me, but the original more yellow.
I'll link when I find the comparison of both shots using Cinema calibrated pic mode: slow pics comparison
aboulfad
#9537 Post by aboulfad » Mon Jan 15, 2024 2:52 pm
other CW test files... On the C2, no reaction at all on any of the test files and the eagle beak looks darker green like in HDR10, not bright yellow as it should.
Neither of these two files show any change on E7 Cinema (calibrated)/Oppo. Full circle, it seems for my setup I have no conclusive mechanism to check that my TV is in TV_Led.
On my E7, there's some interesting relationship with Cinema pic mode & chroma weight where the default cinema doesn't react to changes, while the calibrated DV profile applied to Cinema reacts to the chroma weight changes. Maybe it all doesn't matter, bcoz you said earlier that chroma weight isn't used that often.
#9538 Post by RESET_9999 » Mon Jan 15, 2024 3:05 pm
Now that's strange and sounds like my C2 behavior...
What's the original DV config on your E7?
azreil24
#9539 Post by azreil24 » Mon Jan 15, 2024 3:09 pm
Looks pretty bright yellow to me. Will test it out in HDR10 later, made me curious.
aboulfad
#9540 Post by aboulfad » Mon Jan 15, 2024 3:18 pm
…What's the original DV config on your E7?
Idk! Now that’s what I’ve been searching for. I can’t use bscpylgtv nor any other means to retrieve it from this 2017 TV, nor can I root it bcoz it’s on Webos 3.9.2. I’ve unpacked the firmware & the contents of a Dolby dir but doesn’t show E7 specific files. I did find some OLED_ALL config file…
I’ve also ssh’ed to my TV in dev mode, but that’s a chroot limited mode so I can’t search… how do you know or have your TV’s default DV config ?
