Creating ISO with MakeMKV
Is it possible to create ISOs with MakeMKV, or should I look into alternative software for this specific task?
charnathan
Re: Creating ISO with MakeMKV
DVD's are currently the only format that will create an ISO by default from what I see.
I currently just back-up the BD/UHD disc, then use imgburn to convert it to an ISO file.
And how do you play the ISO file if it's a Blu-ray?charnathan wrote: Fri Jan 26, 2024 4:42 am DVD's are currently the only format that will create an ISO by default from what I see.
Why do you need to create ISO's, are you burning discs? To play an ISO in Windows mount it on a virtual drive, not sure but I think there may be some software players that will directly play an ISO.zerobit wrote: Fri Jan 26, 2024 12:05 pmAnd how do you play the ISO file if it's a Blu-ray?charnathan wrote: Fri Jan 26, 2024 4:42 am DVD's are currently the only format that will create an ISO by default from what I see.
Edit: Apparently VLC can directly plan an ISO.
Windows:
Identifying The Correct Title To Rip: Process Monitor Method - GetMPLS Method
Mux/Remux: Set A Subtitle Stream On By Default (Forced)
charnathan
I mean if you have to ask, then why even ask if MakeMKV can create it?!
I mainly create the ISO's to transfer files faster onto another drive. It's much faster to transfer a single file than it is thousands of files in the back-up folder. Especially when you're moving several movies at once onto a new drive.Nucleus wrote: Fri Jan 26, 2024 3:27 pm Why do you need to create ISO's, are you burning discs? To play an ISO in Windows mount it on a virtual drive, not sure but I think there may be some software players that will directly play an ISO.
And yes, VLC can play ISO's.
VLC can play ISOs but it doesn't give you the menu from the Blu-ray disc. If it's a TV show, you can't even select which episode you want to watch.And yes, VLC can play ISO's.
charnathan
If you do a backup, you get the full menu UI created for the movie/TV show.zerobit wrote: Fri Jan 26, 2024 4:22 pm VLC can play ISOs but it doesn't give you the menu from the Blu-ray disc. If it's a TV show, you can't even select which episode you want to watch.
You do have to make sure you have java installed/upgraded for it to work though
Each to their own of course and obviously we each have our preferred methods.
Unless storage space is of no concern isn't it wasting what could be a lot space storing menus, extras, lots of un needed subtitle and audio streams in the ISO? Is this just for playback on your computer, you can't stream an ISO across a home network to whatever devices, play via TV's media player or some other media player, or can you? As said, each to their own but I prefer main movie only and whatever audio/subs streams I want in the rip. Likewise episodic discs, just each episode.
Windows:
Yeah, you're probably right. It's better to save it as an MKV. I just wanted to know how I can play the full disc with menus and stuff.
I tried installing java but windows doesn't let me.You do have to make sure you have java installed/upgraded for it to work though
You doing online or offline install? If online, you've not got a firewall blocking the install files being downloaded?
Windows Online/Offline Installers:
https://www.java.com/en/download/manual.jsp
Windows:
Nucleus wrote: Sat Jan 27, 2024 5:53 pmYou doing online or offline install? If online, you've not got a firewall blocking the install files being downloaded?
Windows Online/Offline Installers:Code: Select all
- Screenshot_19.png (13.45 KiB) Viewed 34768 times
charnathan
Maybe try downloading it from this link to see if your computer doesn't flag it
https://www.java.com/en/download/Re: Creating ISO with MakeMKV
It's okay, I won't have to use it anyway. I'm guessing there's a security risk involved when it comes to java. I better not install it.
Radiocomms237
It seems pointless making feature requests and bug reports on this forum as they're either being ignored or not even being read by the developer, but...charnathan wrote: Fri Jan 26, 2024 4:42 am DVD's are currently the only format that will create an ISO by default from what I see. ~
I would love it if MakeMKV had the option to make an ISO of Blu-ray's and UltraHDs as well.
Maybe unchecking the "Decrypt video files" option during Backup could then make an ISO of the entire (encrypted) disc, but using the decrypt option could continue to make the indivual folders/files as it does now.
There's no point having the individual encrypted files anyway, you can't do anything with them.
If you want to do this, you don't need go down the ISO path. If you've made a decrypted backup with MakeMKV, just open that backup folder with VLC and it will play as if the disc was in the drive (only much faster), with menus and everything.zerobit wrote: Fri Jan 26, 2024 4:22 pmVLC can play ISOs but it doesn't give you the menu from the Blu-ray disc. If it's a TV show, you can't even select which episode you want to watch.And yes, VLC can play ISO's.
Open VLC MP, click on Media > Open Disc...
Select the "Blu-ray" radio button and make sure "No disc menus" is NOT checked
Now browse for and select the top level of your decrypted backup folder (normally the name of the disc), and click "Play"
As above, it should now play exactly as it would have from the disc.
