What is the "Posix" Error?
PoliteWatcher
#1 Post by PoliteWatcher » Sun Jan 14, 2024 6:12 pm
Hello, I am trying to rip a new (and cleaned) disk but it always fails with the "Posix Error" and "Scsi error".
What are these and how can I work around them?
Thank you.
Re: What is the "Posix" Error?
#2 Post by Woodstock » Sun Jan 14, 2024 7:18 pm
Generally, they are errors reading the disk. Just how the controller sees them is whether it's "posix" or "SCSI".
PoliteWatcher
#3 Post by PoliteWatcher » Sun Jan 14, 2024 11:10 pm
Is there a way to get past this, reinstall software, use different software?
The disk is new and cleaned, of course. Using a drive that can read it, too.
#4 Post by MartyMcNuts » Mon Jan 15, 2024 12:16 am
PoliteWatcher wrote: Sun Jan 14, 2024 11:10 pm Is there a way to get past this, reinstall software, use different software?
What model drive/firmware are you using? Can you try the disc in another drive?
PoliteWatcher
#5 Post by PoliteWatcher » Mon Jan 15, 2024 1:38 am
Hello, and thank you for your kind reply.
I am using version 1.17.5 on a Pioneer BDR-XD07UHD with LibreDrive enabled.
I unfortunately do not have the option to try it on another drive.
Thanks ou for your help, iw as just hoping for some insight as to what the problem was.
#6 Post by MartyMcNuts » Mon Jan 15, 2024 3:30 am
PoliteWatcher wrote: Mon Jan 15, 2024 1:38 am Hello, and thank you for your kind reply.
The problem is the drive is having issues reading the disc.
Your options are to thoroughly clean the disc with soapy water and a microfiber cloth before trying again. If that falls, your options are to try the disc in a different drive or replace the disc.
PoliteWatcher
#7 Post by PoliteWatcher » Sun Feb 02, 2025 1:22 am
MartyMcNuts wrote: Mon Jan 15, 2024 3:30 am
Thank you, mate, that worked! I am sorry for the late reply. Happy New Year and God bless!
