What is the "Posix" Error?
PoliteWatcher
Post by PoliteWatcher »
Hello, I am trying to rip a new (and cleaned) disk but it always fails with the "Posix Error" and "Scsi error".
What are these and how can I work around them?
Thank you.
Re: What is the "Posix" Error?
Generally, they are errors reading the disk. Just how the controller sees them is whether it's "posix" or "SCSI".
PoliteWatcher
Is there a way to get past this, reinstall software, use different software?
The disk is new and cleaned, of course. Using a drive that can read it, too.
PoliteWatcher wrote:
Sun Jan 14, 2024 11:10 pm
What model drive/firmware are you using? Can you try the disc in another drive?
PoliteWatcher
Hello, and thank you for your kind reply.
I am using version 1.17.5 on a Pioneer BDR-XD07UHD with LibreDrive enabled.
I unfortunately do not have the option to try it on another drive.
Thanks ou for your help, iw as just hoping for some insight as to what the problem was.
Mon Jan 15, 2024 1:38 am
The problem is the drive is having issues reading the disc.
Your options are to thoroughly clean the disc with soapy water and a microfiber cloth before trying again. If that falls, your options are to try the disc in a different drive or replace the disc.
PoliteWatcher
MartyMcNuts wrote:
Mon Jan 15, 2024 3:30 am
Thank you, mate, that worked! I am sorry for the late reply. Happy New Year and God bless!
