BDR-XS07S UHD Flash
hydra
BDR-XS07S UHD Flash
#1 Post by hydra » Thu Jan 11, 2024 6:37 pm
Is it possible to flash this drive to read UHD disks? Here are the specs according to MakeMKV:
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.01
Serial number: Removed
Firmware date: 2020-09-03
Bus encryption flags: 13
Highest AACS version: 70
Drive platform: RS8E20
Firmware version: 1.01
Re: BDR-XS07S UHD Flash
#2 Post by Coopervid » Thu Jan 11, 2024 7:51 pm
OS device name: F:
Revision: 1.01
Check PM
hydra
#3 Post by hydra » Fri Jan 12, 2024 4:21 pm
Hi Coopervid, I'm assuming it's because I just registered yesterday, but I'm not seeing an option to respond to your PM.
Can you tell me how the flasher works? Is it physical or software? Sorry if this is a noob question; this is all very new to me.
#4 Post by Coopervid » Fri Jan 12, 2024 4:42 pm
Software. Check PM.
hydra
#5 Post by hydra » Fri Jan 12, 2024 5:56 pm
It seems to have worked, thank you! I'm ripping a 4k disk now, so we'll see how it turns out.
InfDisco
#6 Post by InfDisco » Sun Jan 14, 2024 8:36 pm
Hello, I actually picked up this same drive yesterday and it has the same firmware. What was the solution to make it work? Thanks!
qlxel
#7 Post by qlxel » Sat Jan 20, 2024 3:31 pm
Hello everyone here,
just as the others here I too recently picked up a BDR-XS07TS recently and would like to know how to get it up to UHD.
I'm aware of Billycar11's Auto flash kit for 25, but it sounds here like there might be another way too.
Just like hydra I can not yet send PMs.
fstchevy
#8 Post by fstchevy » Fri Mar 15, 2024 12:24 am
Where did you guys buy your drives from? I just purchased one from BH Photo and unfortunately it has 1.03.
mrcobra92
#9 Post by mrcobra92 » Wed Mar 20, 2024 2:05 pm
Hello! I just picked up one of these drives as well and it has firmware 1.01! Can someone please PM me or point me in the direction of how to flash the UHD firmware on this? Thanks!
#10 Post by Coopervid » Wed Mar 20, 2024 2:16 pm
Check PM.
qlxel
#11 Post by qlxel » Wed Mar 20, 2024 2:21 pm
Hello Coopervid,
could you please send me the instructions as well?
#12 Post by Coopervid » Wed Mar 20, 2024 4:44 pm
Hello Coopervid,
Check PM.
qlxel
#13 Post by qlxel » Wed Mar 20, 2024 8:56 pm
Apparently I can't even answer to PMs yet, so big thanks here to Coopervid, flash worked without a problem with FW 1.01
sense
#14 Post by sense » Mon Mar 25, 2024 9:26 pm
Hello Coopervid,
could you please send me the instructions to downgrade the XS07U to a libredrive firmware ?
Edward1017
#15 Post by Edward1017 » Mon Apr 01, 2024 7:17 am
Hello Coopervid,
I also picked up one of these drives recently. Mine is on firmware 1.00.
Can you also PM me with the instructions?
