Five Nights At Freddy's dump
zettee
Post by zettee »
Hi all,
I wanted to backup this disk, but it failed to open using MakeMKV. I uploaded the dump that was generated.
I found this thread with the same problem: viewtopic.php?t=32635#top
But this time it seems to be a different version of the disk? (my dump ends with 8C4A, instead of 3ECA)
Re: Five Nights At Freddy's dump
It is often the case the different batches of the same title need a different hashed key for decryption. Emailing your dump was the right thing to do. You could've just posted in an existing Five Nights at Freddy's thread that you emailed in the specific key you had and that would've been okay too.
