Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
mookieman
#1 Post by mookieman » Sat Jan 13, 2024 9:46 pm
Just had this delivered, it reads BluRay's no problem but when I insert any UHD Discs it does not read them, it just says "No Disc Inserted". I was using an Asus 5.25 internal drive until it decided to completely shred a UHD copy of Dunkirk on me. The UHD's I tested, Arrival and Blade Runner have already been ripped with the Asus drive before it went doolally.
Here's the MKV Info for the drive in question.
Current profile: BD-R SRM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ALDL438296WL
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
#2 Post by MartyMcNuts » Sun Jan 14, 2024 2:12 am
Revision: 1.14
The 43890 (BDR-UD03) is a blu-ray drive, not a UHD drive. The 43888 is the UHD model (containing a BDR-UD04)
mookieman
#3 Post by mookieman » Sun Jan 14, 2024 5:02 am
Ah understood, so there's no way to get this drive to read UHD Discs never mind decrypt them. I think I'll send it back and order one of the recommended ones from your site.
#4 Post by Billycar11 » Sun Jan 14, 2024 8:04 am
You can email me for a automated flasher to this drive to make it read UHD discs
mookieman
#5 Post by mookieman » Sun Jan 14, 2024 8:24 am
Thanks, just sent you an email.
jabie5
#6 Post by jabie5 » Tue Apr 23, 2024 6:38 pm
@ Billcar11,
i have just bought the same drive. Then i found this website, so you are saying this drive can be flashed to read UHD discs. If this is the case can you help.
TIA
jabie5
zittrig
#7 Post by zittrig » Fri Oct 18, 2024 4:46 pm
I've a 43890 and the original Verbatim firmware flasher for the 43888 1.14. Originaly I wanted to reflash my 43888 cause of the BD-read freeze error but my mind goes on....
Is there any way to get the 43890 flashed with it? By execute an error occurs that the target is not found.
#8 Post by Coopervid » Fri Oct 18, 2024 4:48 pm
No. Read your PM.
zittrig
#9 Post by zittrig » Fri Oct 18, 2024 5:26 pm
Great, thank you very much. :)
I've answered with PM but the message is hanging around in the Outbox, it's not sent.
#10 Post by Coopervid » Fri Oct 18, 2024 5:38 pm
It was sent. It needs to be read. Until then it's in the outbox.
rosti
#11 Post by rosti » Mon Dec 09, 2024 12:03 pm
Hey guys, same problem here - I have bought recently Verbatim 43890 (BD-RW BDR-UD03 / FW: BDR-US03 1.14)
Is it possible to make it work with UHDs?
#12 Post by Coopervid » Mon Dec 09, 2024 1:54 pm
Read your PM.
rosti
#13 Post by rosti » Mon Dec 09, 2024 6:46 pm
Coopervid, thank you very much for the message :D
bobraptors
#14 Post by bobraptors » Fri Dec 27, 2024 2:26 am
Hi everyone, I just found this thread online, and I'm looking to flash my newly purchased Verbatim 43890 to support UHD discs.
  • Can someone please point me to the flashing the FW & instructions
    Any drawbacks after flashing
Greatly appreciated
#15 Post by Coopervid » Fri Dec 27, 2024 11:38 am
Greatly appreciated
PM sent.
