valington
#9496 Post by valington » Fri Jan 12, 2024 7:13 pm
RESET_9999 wrote:
Fri Jan 12, 2024 1:41 pm
azreil24 wrote:
Fri Jan 12, 2024 1:34 pm
I tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
No issue on my end and there is no difference between the mp4/ts or mkv version, its all the same script. I know drag and drop doesn't work on Windows 11 if you launch the script in admin rights.
I wouldn't use the auto ocr sup to srt though.
YES script doing audio and subtitles two times in mp4 7 profile mode and something wrong with dolby vision layers they are wrong plese fix it
#9497 Post by RESET_9999 » Fri Jan 12, 2024 7:27 pm
please try the version posted yersterday here
aboulfad
#9498 Post by aboulfad » Fri Jan 12, 2024 7:37 pm
RESET_9999 wrote:
Fri Jan 12, 2024 6:05 pm
...Speaking of Chroma Weight, the latest amazon prime original movie does use it quite a lot. And IMO there's a much more concerning bug with TV-LED where any positive lift for trims offset doesn't work.
Oh you mean the Prime movie "Role Play", anything one should watch for related to this "bug" ? i.e. is it visible to the naked eye in some scene ?
#9499 Post by RESET_9999 » Fri Jan 12, 2024 7:43 pm
All the HDMI devices I tested will ignore any positive lift for Trim offset so it will reflect in a darker image.
test file if you want to see it with your own eyes: https://drive.google.com/file/d/1JrU6JX ... drive_link
This is a much bigger issue than the LLDV CW bug because L2 trim offset is calculated automatically by the Dolby algo (then the colorist can edit it) so unlike Chroma Weight which must come from the colorist, trim offset is used a lot more often in real content and only the TV internal player support it. (ironically, all the devices support it just fine in LLDV)
aboulfad
#9500 Post by aboulfad » Fri Jan 12, 2024 8:03 pm
I assume I need to check around 2 minutes in the video for the L1 + 'trim chroma weight' ? if so, using Oppo/Cinema on my TV, I couldn't spot anything different. For other segments, I did see a change.
#9501 Post by RESET_9999 » Fri Jan 12, 2024 8:06 pm
I'm talking about L2 trim offset, not CW which doesn't have an effect in that frame.
JCLG8
#9502 Post by JCLG8 » Fri Jan 12, 2024 8:09 pm
RESET_9999 wrote:
Fri Jan 12, 2024 7:07 pm
JCLG8 wrote:
Fri Jan 12, 2024 6:49 pm
I assume I just copy the text from the command line for the log, but what is echo and how do I turn it on?
open the bat file with notepad and change the 2nd line
@echo on
Here's the mediainfo:
General
Unique ID                                : 272637323767375241025497333302978112812 (0xCD1C09E062FB952F31546ED5A75F6D2C)
Complete name                            : F:\new\Dredd.2012.2160p.UHD.BDRemux.HDR.DV.x265.TrueHD7.1-DVT.mkv
Format version                           : Version 2
File size                                : 62.2 GiB
Duration                                 : 1 h 36 min
Overall bit rate                         : 92.5 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : Dredd (2012) - Release by Dolby Vision Torrents
Encoded date                             : 2021-06-21 10:08:56 UTC
Writing application                      : MakeMKV v1.16.3 win(x64-release)
Writing library                          : libmakemkv v1.16.3 (1.3.10/1.5.2) win(x64-release)
Cover                                    : Yes
Attachments                              : Cover.jpg
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 70.0 Mb/s
Bits/(Pixel*Frame)                       : 0.352
Stream size                              : 47.1 GiB (76%)
Title                                    : Remux by VoX
Mastering display luminance              : min: 0.0020 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 10000 cd/m2
Maximum Frame-Average Light Level        : 1578 cd/m2
Audio #1
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Bit rate                                 : 2 268 kb/s
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 16 bits
Stream size                              : 1.52 GiB (2%)
Title                                    : Dub, Blu-Ray
Language                                 : Russian
Audio #2
Format                                   : DTS XLL
Bit rate                                 : 4 966 kb/s
Channel layout                           : C L R LFE Lb Rb Lss Rss
Stream size                              : 3.34 GiB (5%)
Title                                    : AVO, А.Гаврилов
Language                                 : Russian
Audio #3
Format                                   : DTS XLL
Bit rate                                 : 4 985 kb/s
Stream size                              : 3.35 GiB (5%)
Title                                    : AVO, Ю.Сербин
Language                                 : Russian
Audio #4
Format                                   : DTS XLL
Bit rate                                 : 4 975 kb/s
Title                                    : VO, М.Яроцкий
Language                                 : Russian
Audio #5
Format                                   : TrueHD
Duration                                 : 1 h 35 min
Bit rate                                 : 4 632 kb/s
Stream size                              : 3.10 GiB (5%)
Title                                    : Original
Audio #6
Format settings                          : Dolby Surround EX
Codec ID                                 : A_AC3
Stream size                              : 441 MiB (1%)
Title                                    : Original
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 1 h 28 min
Bit rate                                 : 69 b/s
Frame rate                               : 0.138 FPS
Count of elements                        : 733
Stream size                              : 45.2 KiB (0%)
Title                                    : Blu-Ray
Language                                 : Russian
Text #2
Format                                   : UTF-8
Bit rate                                 : 68 b/s
Frame rate                               : 0.139 FPS
Count of elements                        : 737
Stream size                              : 44.1 KiB (0%)
Title                                    : Groby
Language                                 : Russian
Text #3
Format                                   : UTF-8
Bit rate                                 : 61 b/s
Frame rate                               : 0.167 FPS
Count of elements                        : 882
Stream size                              : 39.8 KiB (0%)
Title                                    : Antoniolagrande
Language                                 : Russian
Text #4
Format                                   : UTF-8
Bit rate                                 : 63 b/s
Frame rate                               : 0.128 FPS
Count of elements                        : 680
Stream size                              : 41.2 KiB (0%)
Title                                    : Ясень
Language                                 : Russian
Text #5
Format                                   : UTF-8
Duration                                 : 1 h 29 min
Bit rate                                 : 64 b/s
Frame rate                               : 0.126 FPS
Count of elements                        : 674
Stream size                              : 42.3 KiB (0%)
Title                                    : Notabenoid
Language                                 : Russian
Text #6
Format                                   : UTF-8
Bit rate                                 : 42 b/s
Frame rate                               : 0.143 FPS
Count of elements                        : 754
Stream size                              : 27.3 KiB (0%)
Title                                    : Full
Text #7
Format                                   : UTF-8
Bit rate                                 : 46 b/s
Frame rate                               : 0.191 FPS
Count of elements                        : 1011
Stream size                              : 29.9 KiB (0%)
Title                                    : SDH
Menu
00:00:00.000                             : en:Chapter 01
00:08:37.475                             : en:Chapter 02
00:18:17.387                             : en:Chapter 03
00:30:23.446                             : en:Chapter 04
00:39:51.222                             : en:Chapter 05
00:48:24.526                             : en:Chapter 06
00:59:06.125                             : en:Chapter 07
01:10:05.451                             : en:Chapter 08
01:19:55.791                             : en:Chapter 09
01:29:40.708                             : en:Chapter 10
And here's a link to the log: https://drive.google.com/file/d/1AdQHjj ... sp=sharing
aboulfad
#9503 Post by aboulfad » Fri Jan 12, 2024 8:16 pm
Ah sorry, excuse my lack of attention, the label confused me as its L1 + ... but of course 'trim offset' is a function of L2. Indeed, its quite noticeable, @1024 its super dark !
#9504 Post by RESET_9999 » Fri Jan 12, 2024 8:27 pm
This is workflow 5??
I thought you wanted to demux ST P7 MKV to DT-DL TS ???
the workflow to do that is (4-3)
Workflow is supposed to work though but the output would still be ST P7 which could fail to play on the x700. I'll try to reproduce the issue but my guess is because of the Russian text for the dts tracks
#9505 Post by RESET_9999 » Fri Jan 12, 2024 8:28 pm
yea negative values (below 2048) works but the problem is with the positive lift. Try it on your TV internal player or force LLDV on your oppo, you'll see.
JCLG8
#9506 Post by JCLG8 » Fri Jan 12, 2024 8:35 pm
Ah crap yeah forgot to mention this, sorry. I thought maybe ST DL will work so I don't need to convert so then I tried to just mux it as is to .TS. But honestly the same issue with TrueHD happens on both situations.
#9507 Post by RESET_9999 » Fri Jan 12, 2024 8:37 pm
Ah crap sorry. I thought maybe ST DL will work so I don't need to convert so then I tried to just mux it as is to .TS. But honestly the same issue with TrueHD happens on both situations.
If you just mux it with tsmuxer the THD track will not work on the x700 because it will be missing the AC3 core.
#9508 Post by RESET_9999 » Fri Jan 12, 2024 8:48 pm
PS, I'm not able to reproduce the issue. Can you try with a normal rip that doesn't come from some obscure Russian torrent tracker please??
JCLG8
#9509 Post by JCLG8 » Fri Jan 12, 2024 9:17 pm
Lol its not obscure its quite known actually but I understand.
speeddemon
#9510 Post by speeddemon » Fri Jan 12, 2024 10:27 pm
Is the positive trim lift ignored by every TV-led device? e.g. Every Blu-ray player, Apple TV, and Shield in TV-led mode?
Also, is there any chance that it is intentional for the positive lift L2 Trim to be ignored on TV-led devices if that is the case? Maybe Dolby determined that the TV should make its own decision in those cases...?
