Here's the mediainfo:RESET_9999 wrote: Fri Jan 12, 2024 7:07 pmopen the bat file with notepad and change the 2nd lineJCLG8 wrote: Fri Jan 12, 2024 6:49 pm I assume I just copy the text from the command line for the log, but what is echo and how do I turn it on?
@echo on
General
Unique ID : 272637323767375241025497333302978112812 (0xCD1C09E062FB952F31546ED5A75F6D2C)
Complete name : F:\new\Dredd.2012.2160p.UHD.BDRemux.HDR.DV.x265.TrueHD7.1-DVT.mkv
Format : Matroska
Format version : Version 2
File size : 62.2 GiB
Duration : 1 h 36 min
Overall bit rate mode : Variable
Overall bit rate : 92.5 Mb/s
Frame rate : 23.976 FPS
Movie name : Dredd (2012) - Release by Dolby Vision Torrents
Encoded date : 2021-06-21 10:08:56 UTC
Writing application : MakeMKV v1.16.3 win(x64-release)
Writing library : libmakemkv v1.16.3 (1.3.10/1.5.2) win(x64-release)
Cover : Yes
Attachments : Cover.jpg
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 70.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.352
Stream size : 47.1 GiB (76%)
Title : Remux by VoX
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Level : 1578 cd/m2
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 2 268 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 1.52 GiB (2%)
Title : Dub, Blu-Ray
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 966 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Bit depth : 24 bits
Stream size : 3.34 GiB (5%)
Title : AVO, А.Гаврилов
Language : Russian
Default : No
Forced : No
Audio #3
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 985 kb/s
Bit depth : 24 bits
Stream size : 3.35 GiB (5%)
Title : AVO, Ю.Сербин
Language : Russian
Default : No
Forced : No
Audio #4
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 975 kb/s
Bit depth : 24 bits
Title : VO, М.Яроцкий
Language : Russian
Default : No
Forced : No
Audio #5
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1 h 35 min
Bit rate : 4 632 kb/s
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Stream size : 3.10 GiB (5%)
Title : Original
Language : English
Default : No
Forced : No
Audio #6
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 441 MiB (1%)
Title : Original
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 28 min
Bit rate : 69 b/s
Frame rate : 0.138 FPS
Count of elements : 733
Stream size : 45.2 KiB (0%)
Title : Blu-Ray
Language : Russian
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 68 b/s
Frame rate : 0.139 FPS
Count of elements : 737
Stream size : 44.1 KiB (0%)
Title : Groby
Language : Russian
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 61 b/s
Frame rate : 0.167 FPS
Count of elements : 882
Stream size : 39.8 KiB (0%)
Title : Antoniolagrande
Language : Russian
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 63 b/s
Frame rate : 0.128 FPS
Count of elements : 680
Stream size : 41.2 KiB (0%)
Title : Ясень
Language : Russian
Default : No
Forced : No
Text #5
Format : UTF-8
Duration : 1 h 29 min
Bit rate : 64 b/s
Frame rate : 0.126 FPS
Count of elements : 674
Stream size : 42.3 KiB (0%)
Title : Notabenoid
Language : Russian
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 42 b/s
Frame rate : 0.143 FPS
Count of elements : 754
Stream size : 27.3 KiB (0%)
Title : Full
Language : English
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 46 b/s
Frame rate : 0.191 FPS
Count of elements : 1011
Stream size : 29.9 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:08:37.475 : en:Chapter 02
00:18:17.387 : en:Chapter 03
00:30:23.446 : en:Chapter 04
00:39:51.222 : en:Chapter 05
00:48:24.526 : en:Chapter 06
00:59:06.125 : en:Chapter 07
01:10:05.451 : en:Chapter 08
01:19:55.791 : en:Chapter 09
01:29:40.708 : en:Chapter 10
