JCLG8
Post by JCLG8 »
RESET_9999 wrote:
Fri Jan 12, 2024 7:07 pm
JCLG8 wrote:
Fri Jan 12, 2024 6:49 pm
I assume I just copy the text from the command line for the log, but what is echo and how do I turn it on?
open the bat file with notepad and change the 2nd line
@echo on
Here's the mediainfo:
General
Unique ID                                : 272637323767375241025497333302978112812 (0xCD1C09E062FB952F31546ED5A75F6D2C)
Complete name                            : F:\new\Dredd.2012.2160p.UHD.BDRemux.HDR.DV.x265.TrueHD7.1-DVT.mkv
Format version                           : Version 2
File size                                : 62.2 GiB
Duration                                 : 1 h 36 min
Overall bit rate                         : 92.5 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : Dredd (2012) - Release by Dolby Vision Torrents
Encoded date                             : 2021-06-21 10:08:56 UTC
Writing application                      : MakeMKV v1.16.3 win(x64-release)
Writing library                          : libmakemkv v1.16.3 (1.3.10/1.5.2) win(x64-release)
Cover                                    : Yes
Attachments                              : Cover.jpg
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 70.0 Mb/s
Bits/(Pixel*Frame)                       : 0.352
Stream size                              : 47.1 GiB (76%)
Title                                    : Remux by VoX
Mastering display luminance              : min: 0.0020 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 10000 cd/m2
Maximum Frame-Average Light Level        : 1578 cd/m2
Audio #1
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Bit rate                                 : 2 268 kb/s
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 16 bits
Stream size                              : 1.52 GiB (2%)
Title                                    : Dub, Blu-Ray
Language                                 : Russian
Audio #2
Format                                   : DTS XLL
Bit rate                                 : 4 966 kb/s
Channel layout                           : C L R LFE Lb Rb Lss Rss
Stream size                              : 3.34 GiB (5%)
Title                                    : AVO, А.Гаврилов
Language                                 : Russian
Audio #3
Format                                   : DTS XLL
Bit rate                                 : 4 985 kb/s
Stream size                              : 3.35 GiB (5%)
Title                                    : AVO, Ю.Сербин
Language                                 : Russian
Audio #4
Format                                   : DTS XLL
Bit rate                                 : 4 975 kb/s
Title                                    : VO, М.Яроцкий
Language                                 : Russian
Audio #5
Format                                   : TrueHD
Duration                                 : 1 h 35 min
Bit rate                                 : 4 632 kb/s
Stream size                              : 3.10 GiB (5%)
Title                                    : Original
Audio #6
Format settings                          : Dolby Surround EX
Codec ID                                 : A_AC3
Stream size                              : 441 MiB (1%)
Title                                    : Original
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 1 h 28 min
Bit rate                                 : 69 b/s
Frame rate                               : 0.138 FPS
Count of elements                        : 733
Stream size                              : 45.2 KiB (0%)
Title                                    : Blu-Ray
Language                                 : Russian
Text #2
Format                                   : UTF-8
Bit rate                                 : 68 b/s
Frame rate                               : 0.139 FPS
Count of elements                        : 737
Stream size                              : 44.1 KiB (0%)
Title                                    : Groby
Language                                 : Russian
Text #3
Format                                   : UTF-8
Bit rate                                 : 61 b/s
Frame rate                               : 0.167 FPS
Count of elements                        : 882
Stream size                              : 39.8 KiB (0%)
Title                                    : Antoniolagrande
Language                                 : Russian
Text #4
Format                                   : UTF-8
Bit rate                                 : 63 b/s
Frame rate                               : 0.128 FPS
Count of elements                        : 680
Stream size                              : 41.2 KiB (0%)
Title                                    : Ясень
Language                                 : Russian
Text #5
Format                                   : UTF-8
Duration                                 : 1 h 29 min
Bit rate                                 : 64 b/s
Frame rate                               : 0.126 FPS
Count of elements                        : 674
Stream size                              : 42.3 KiB (0%)
Title                                    : Notabenoid
Language                                 : Russian
Text #6
Format                                   : UTF-8
Bit rate                                 : 42 b/s
Frame rate                               : 0.143 FPS
Count of elements                        : 754
Stream size                              : 27.3 KiB (0%)
Title                                    : Full
Text #7
Format                                   : UTF-8
Bit rate                                 : 46 b/s
Frame rate                               : 0.191 FPS
Count of elements                        : 1011
Stream size                              : 29.9 KiB (0%)
Title                                    : SDH
Menu
00:00:00.000                             : en:Chapter 01
00:08:37.475                             : en:Chapter 02
00:18:17.387                             : en:Chapter 03
00:30:23.446                             : en:Chapter 04
00:39:51.222                             : en:Chapter 05
00:48:24.526                             : en:Chapter 06
00:59:06.125                             : en:Chapter 07
01:10:05.451                             : en:Chapter 08
01:19:55.791                             : en:Chapter 09
01:29:40.708                             : en:Chapter 10
And here's a link to the log: https://drive.google.com/file/d/1AdQHjj ... sp=sharing
aboulfad
Post by aboulfad »
RESET_9999 wrote:
Fri Jan 12, 2024 8:06 pm
I'm talking about L2 trim offset, not CW which doesn't have an effect in that frame.
Ah sorry, excuse my lack of attention, the label confused me as its L1 + ... but of course 'trim offset' is a function of L2. Indeed, its quite noticeable, @1024 its super dark !
JCLG8 wrote:
Fri Jan 12, 2024 8:09 pm
This is workflow 5??
I thought you wanted to demux ST P7 MKV to DT-DL TS ???
the workflow to do that is (4-3)
Workflow is supposed to work though but the output would still be ST P7 which could fail to play on the x700. I'll try to reproduce the issue but my guess is because of the Russian text for the dts tracks
aboulfad wrote:
Fri Jan 12, 2024 8:16 pm
yea negative values (below 2048) works but the problem is with the positive lift. Try it on your TV internal player or force LLDV on your oppo, you'll see.
JCLG8
Post by JCLG8 »
RESET_9999 wrote:
Fri Jan 12, 2024 8:27 pm
Ah crap yeah forgot to mention this, sorry. I thought maybe ST DL will work so I don't need to convert so then I tried to just mux it as is to .TS. But honestly the same issue with TrueHD happens on both situations.
JCLG8 wrote:
Fri Jan 12, 2024 8:35 pm
Ah crap sorry. I thought maybe ST DL will work so I don't need to convert so then I tried to just mux it as is to .TS. But honestly the same issue with TrueHD happens on both situations.
If you just mux it with tsmuxer the THD track will not work on the x700 because it will be missing the AC3 core.
PS, I'm not able to reproduce the issue. Can you try with a normal rip that doesn't come from some obscure Russian torrent tracker please??
JCLG8
Post by JCLG8 »
RESET_9999 wrote:
Fri Jan 12, 2024 8:48 pm
Lol its not obscure its quite known actually but I understand.
speeddemon
Post by speeddemon »
RESET_9999 wrote:
Fri Jan 12, 2024 7:43 pm
All the HDMI devices I tested will ignore any positive lift for Trim offset so it will reflect in a darker image.
test file if you want to see it with your own eyes: https://drive.google.com/file/d/1JrU6JX ... drive_link
This is a much bigger issue than the LLDV CW bug because L2 trim offset is calculated automatically by the Dolby algo (then the colorist can edit it) so unlike Chroma Weight which must come from the colorist, trim offset is used a lot more often in real content and only the TV internal player support it. (ironically, all the devices support it just fine in LLDV)
Is the positive trim lift ignored by every TV-led device? e.g. Every Blu-ray player, Apple TV, and Shield in TV-led mode?
Also, is there any chance that it is intentional for the positive lift L2 Trim to be ignored on TV-led devices if that is the case? Maybe Dolby determined that the TV should make its own decision in those cases...?
Yes, I tested with two different TV (C8 and C2):
x700
x800m2
shield
ATV
I doubt this is intentional otherwise it would also be ignored when you play the file with the TV internal player.
skull88
Post by skull88 »
speeddemon wrote:
Fri Jan 12, 2024 10:27 pm
I agree with RESET, it also doesn't make sense for Dolby's own Professional Tools to generate positive trims when run automatically, if they intend for them to be ignored. I haven't seen/read any Dolby official articles or manuals mention advising against positive values on any trim adjustments when grading either, other than positive lift not being above 0.025 for letterbox content, see here: https://www.youtube.com/watch?v=AVZ7xcgeEAM
speeddemon
RESET_9999 wrote:
Fri Jan 12, 2024 10:56 pm
x700
x800m2
shield
ATV
So the C8 & C2 don't have the issue when you're using the internal player? How about Kodi?
I want to test this from my Sony A95K to see if it behaves the same way... wondering if maybe this is an LG behavior... or is that not possible?
Does Dolby state this for a different reason?
Avoid using positive values over 0.025 on the LIFT trim control for letterboxed content. (Negative Lift values are acceptable on all versions).
Source: https://professionalsupport.dolby.com/s ... uage=en_US
right C8 and C2 internal players do not have this bug. I haven't tested kodi but I don't see why it would be any different.
yes but they still can lift up to 0.025 which is ignored by the HDMI players and if the content is full screen then there is no restriction so this cannot be the reason plus they can lift with the other trim control as well.
Also, they can use the metafier to verify or fix any lift.
susanstone2022
Post by susanstone2022 »
RESET_9999 wrote:
Fri Jan 12, 2024 11:27 pm
We really don't know how TV process DV signals. One possible explanation is internal player is doing LLDV.
susanstone2022
x700
x800m2
shield
ATV
This was one of my questions in my previous post - is this metadata actually used?
L2 trims are "per-target trim metadata" - typically 100nits, 600nits, 1000nits. How would TVs or players use this data?
If the TV happens to be one of these three numbers, it can use one of them.
If the TV is 350nits, 800nits, 1500nits, 2000nits, which L2 metadata would it use? use the closest one? or extrapolation? for example, 800nits TV will use both 600nits+1000nits?
Can you see internal player output? I think Kodi can show its output. If we know what signal come out of internal player, we can do better troubleshooting.
