YES script doing audio and subtitles two times in mp4 7 profile mode and something wrong with dolby vision layers they are wrong plese fix itRESET_9999 wrote: ↑Fri Jan 12, 2024 1:41 pmNo issue on my end and there is no difference between the mp4/ts or mkv version, its all the same script. I know drag and drop doesn't work on Windows 11 if you launch the script in admin rights.azreil24 wrote: ↑Fri Jan 12, 2024 1:34 pmI tried playing with some more converting from MKV into MP4 and TS and it seems these two scripts have issues with file drop, they do not pick up the file path, I had to enter it manually for both. MKV script seems to work fine. Also, the MP4 converting flow processed the audio and subs two times, although I only had one of each.
I wouldn't use the auto ocr sup to srt though.
please try the version posted yersterday here
Oh you mean the Prime movie "Role Play", anything one should watch for related to this "bug" ? i.e. is it visible to the naked eye in some scene ?RESET_9999 wrote: ↑Fri Jan 12, 2024 6:05 pm...Speaking of Chroma Weight, the latest amazon prime original movie does use it quite a lot. And IMO there's a much more concerning bug with TV-LED where any positive lift for trims offset doesn't work.
All the HDMI devices I tested will ignore any positive lift for Trim offset so it will reflect in a darker image.
test file if you want to see it with your own eyes: https://drive.google.com/file/d/1JrU6JX ... drive_link
This is a much bigger issue than the LLDV CW bug because L2 trim offset is calculated automatically by the Dolby algo (then the colorist can edit it) so unlike Chroma Weight which must come from the colorist, trim offset is used a lot more often in real content and only the TV internal player support it. (ironically, all the devices support it just fine in LLDV)
I assume I need to check around 2 minutes in the video for the L1 + 'trim chroma weight' ? if so, using Oppo/Cinema on my TV, I couldn't spot anything different. For other segments, I did see a change.
I'm talking about L2 trim offset, not CW which doesn't have an effect in that frame.
Here's the mediainfo:RESET_9999 wrote: ↑Fri Jan 12, 2024 7:07 pmopen the bat file with notepad and change the 2nd line
@echo on
General
Unique ID : 272637323767375241025497333302978112812 (0xCD1C09E062FB952F31546ED5A75F6D2C)
Complete name : F:\new\Dredd.2012.2160p.UHD.BDRemux.HDR.DV.x265.TrueHD7.1-DVT.mkv
Format : Matroska
Format version : Version 2
File size : 62.2 GiB
Duration : 1 h 36 min
Overall bit rate mode : Variable
Overall bit rate : 92.5 Mb/s
Frame rate : 23.976 FPS
Movie name : Dredd (2012) - Release by Dolby Vision Torrents
Encoded date : 2021-06-21 10:08:56 UTC
Writing application : MakeMKV v1.16.3 win(x64-release)
Writing library : libmakemkv v1.16.3 (1.3.10/1.5.2) win(x64-release)
Cover : Yes
Attachments : Cover.jpg
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 70.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.352
Stream size : 47.1 GiB (76%)
Title : Remux by VoX
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0020 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Level : 1578 cd/m2
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 2 268 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 1.52 GiB (2%)
Title : Dub, Blu-Ray
Language : Russian
Default : Yes
Forced : No
Audio #2
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 966 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Bit depth : 24 bits
Stream size : 3.34 GiB (5%)
Title : AVO, А.Гаврилов
Language : Russian
Default : No
Forced : No
Audio #3
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 985 kb/s
Bit depth : 24 bits
Stream size : 3.35 GiB (5%)
Title : AVO, Ю.Сербин
Language : Russian
Default : No
Forced : No
Audio #4
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 975 kb/s
Bit depth : 24 bits
Title : VO, М.Яроцкий
Language : Russian
Default : No
Forced : No
Audio #5
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 1 h 35 min
Bit rate : 4 632 kb/s
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Stream size : 3.10 GiB (5%)
Title : Original
Language : English
Default : No
Forced : No
Audio #6
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 441 MiB (1%)
Title : Original
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 28 min
Bit rate : 69 b/s
Frame rate : 0.138 FPS
Count of elements : 733
Stream size : 45.2 KiB (0%)
Title : Blu-Ray
Language : Russian
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 68 b/s
Frame rate : 0.139 FPS
Count of elements : 737
Stream size : 44.1 KiB (0%)
Title : Groby
Language : Russian
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 61 b/s
Frame rate : 0.167 FPS
Count of elements : 882
Stream size : 39.8 KiB (0%)
Title : Antoniolagrande
Language : Russian
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 63 b/s
Frame rate : 0.128 FPS
Count of elements : 680
Stream size : 41.2 KiB (0%)
Title : Ясень
Language : Russian
Default : No
Forced : No
Text #5
Format : UTF-8
Duration : 1 h 29 min
Bit rate : 64 b/s
Frame rate : 0.126 FPS
Count of elements : 674
Stream size : 42.3 KiB (0%)
Title : Notabenoid
Language : Russian
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 42 b/s
Frame rate : 0.143 FPS
Count of elements : 754
Stream size : 27.3 KiB (0%)
Title : Full
Language : English
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 46 b/s
Frame rate : 0.191 FPS
Count of elements : 1011
Stream size : 29.9 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:08:37.475 : en:Chapter 02
00:18:17.387 : en:Chapter 03
00:30:23.446 : en:Chapter 04
00:39:51.222 : en:Chapter 05
00:48:24.526 : en:Chapter 06
00:59:06.125 : en:Chapter 07
01:10:05.451 : en:Chapter 08
01:19:55.791 : en:Chapter 09
01:29:40.708 : en:Chapter 10
Ah sorry, excuse my lack of attention, the label confused me as its L1 + ... but of course 'trim offset' is a function of L2. Indeed, its quite noticeable, @1024 its super dark !RESET_9999 wrote: ↑Fri Jan 12, 2024 8:06 pmI'm talking about L2 trim offset, not CW which doesn't have an effect in that frame.
This is workflow 5??
I thought you wanted to demux ST P7 MKV to DT-DL TS ???
the workflow to do that is (4-3)
Workflow is supposed to work though but the output would still be ST P7 which could fail to play on the x700. I'll try to reproduce the issue but my guess is because of the Russian text for the dts tracks
yea negative values (below 2048) works but the problem is with the positive lift. Try it on your TV internal player or force LLDV on your oppo, you'll see.
Ah crap yeah forgot to mention this, sorry. I thought maybe ST DL will work so I don't need to convert so then I tried to just mux it as is to .TS. But honestly the same issue with TrueHD happens on both situations.RESET_9999 wrote: ↑Fri Jan 12, 2024 8:27 pmThis is workflow 5??
If you just mux it with tsmuxer the THD track will not work on the x700 because it will be missing the AC3 core.
PS, I'm not able to reproduce the issue. Can you try with a normal rip that doesn't come from some obscure Russian torrent tracker please??
Lol its not obscure its quite known actually but I understand.RESET_9999 wrote: ↑Fri Jan 12, 2024 8:48 pmPS, I'm not able to reproduce the issue. Can you try with a normal rip that doesn't come from some obscure Russian torrent tracker please??
Is the positive trim lift ignored by every TV-led device? e.g. Every Blu-ray player, Apple TV, and Shield in TV-led mode?RESET_9999 wrote: ↑Fri Jan 12, 2024 7:43 pmAll the HDMI devices I tested will ignore any positive lift for Trim offset so it will reflect in a darker image.
Also, is there any chance that it is intentional for the positive lift L2 Trim to be ignored on TV-led devices if that is the case? Maybe Dolby determined that the TV should make its own decision in those cases...?
